Fritzing PART CREATION Video Tutorial Series
NEW FASTER PART MAKING VIDEOS AT THE BOTTOM-Fritzing Parts Fast
ADVANCED FRITZING USER TIPS & TRICKS VIDEOS AT THE BOTTOM-Fritzing Adv Tips & Tricks
A series of part creation videos - I’m not an expert, but there was nothing else around at the time.
Use 1080p HD fullscreen to see details clearly - use gear symbol bottom right -.
Recorded slowly for older people, so select a higher speed if it’s too slow.
P.S. - Sorry about the voice/sound :yum:
Fritzing Part Creation - Chapter1 - New Part Editor
0:00 Overview
0:54 Assigning pins/pads
2:06 Changing part drawing
3:18 Locating an image in a directory
3:36 Connector allocation
3:54 Metadata
4:57 Saving as a new part
5:30 Part Property - changing part with Inspector
6:10 Display part label
6:22 CORE parts Vs made parts
6:55 Part Property - Family
8:46 Making a part by substituting drawings
Fritzing Part Creation - Chapter1.5 - Generic to Specific part in Fritzing.
0:00 Overview
0:15 Fudging a part
0:55 Generic IC to specific IC
1:46 Edit pin labels
2:59 SMD
SVG editor for Fritzing parts
Video tutorials
Schematic to svg
Quick Basic Blackbox creation
SparkFun Qwiic Single Relay
Looking for part -- RYS8830
6 AA battery holder
8mm [THT] RGB LED WS2812D-F5
Looking for atmega8535 fritzing part
Guard Rings on SOIC-8 Op Amps
Designing a simple PCB
Create new part,
Properties for custom parts
Can’t find part HR961160C
Looking for x2 safety capacitor and common mode choke
Assigning connectors in Parts editor
Creating Generic Halogen Lapm
OCRA font not accepted
Part seems to have "internal connections"
Bottom Copper Layer Form Problem
MCP73871 Cargador de Baterias
How can I edit schematic image of already existing part?
Request for part : XT60 plug(jack)
MH-ET LIVE Barcode Scanner V3.0
How do I add a variant to a core part?
How do you alter pin placement and spacing in parts editor?
Will pay to have two parts made
Custom copper pad
Help on creating pololu motor shield drv8833
BIGTREETECH EBB42 CAN
ESP8266, AHT2x and BME280 missing
[solved] Switch parts editor to inches?
3-Row Pin Header
Modified SVG file, schematic is updated but in PCB not changes
New to Fritzing - parts repo
Resizing schematic view breaks breadboard view
Help creating a PCB board part (SVG help)
T-Connectors - M&F
First attempt at creating part for Waveshare 1.28 inch round LCD module
Wanted WT32-ETH01
Rotary switch 8 positions 1 pole SR16
Making a schematic friendly part
How can I change the word 'IC' on the top of chips
Assistance Needed for Creating TracoPower TEL 5-2411 Component
Fritzing part for swicher RT9080
Tamyia LED Controller
LoRa Ra-01 but with ESP-12F breakout board
Creating a part
Mysterious connection in custom Choc keyswitch part
Campbell Scientific CR-1000 Fritzing Part
New Inkscape Templates
How to combine SMD and hole?
SVG files for schematic - scaling
Module GPS NEO-6M
Photo Interrupter
Sim900 Part Request
Looking for Wemos Lolin C3 mini / S3 mini
TDS Meter Part Fritzing
Confused about part creation
[Part Request] Metasol "MC-xxx 3-Pole 220v" Magnetic Contactor
Need ESC 2-WAY for brushed motor
LittleBee 20A 2-4 ESC Brushless Motor
Connection snaps to the center of the part, instead of to the pin
Teiledatenbank für alle zugänglich
Esp32-s3-rgb-lcd-driver-board - wroom-1-n8r8
Meanwell - IRM-05-05 - 230V to 5V
LRS-50-5 Can this part be created please
Please help with 3 parts Molex
DS3231 VCC Pin Fix
Ad620 instr amplifier
Finding or making new parts
Arduino Portenta Breakout
How to create Fritzing part from SVG
Stereo potentiometer
Extra libraries for Picaxe
Help for schematic- and breadboardeditor
Problem creating a component
Part Required for a Fuse holder with 15mm pitch
Part Edit crashes
Flipper Protoboard
Need help for my capstone. I need part or library of TTP229
Assistance Required for Creating Component Libraries and Creating Custom PCBs
VS1053 MP3 Shield
Modifiying the Cherry MX Keyswitch part
Keyestudio Parts
Help add Valve DC12V - 6W Solenoid
Adafruit V1 motor shield
Moving pin location in parts editor
Can't find part: FET MPF102 or 2n5457 or compatible
PLCC 84 socket part?
18650 Battery Holder Part Design
Add enter-able property box for parts in Inspector
Doit esp32 devkit v1
Request - IRF520 MosFET module
SOLVED - 7 Segment Single Digit Display
A discussion of future direction
Befuddled by the terminology and lost in the technology!
Any 5 pin TO-220 packages already available?
[Request] Wanting to pay to get a few parts made
Waterproof IP68 5pin plugs parts? Anyone?
Are top down viewed components available in Fritzing?
Creating Custom Parts for Robotics Competition
Editor parts pin distance at pcb
Editing Parts SVGs
Creating QFN-24 3.5mm x 3.5mm
4x5 Key switch pad with LEDs (YL-4)
Creating a new part PIC16F887
DB37 and 12V battery - Megasquirt
PCB Parts Editor Pin Selection Not Working
Learning Fritzing, beginning difficulties
Issue in Fritzing Parts of PICO 2 RP2350
Help me to find some modules
Custom copper logo not displaying in fab
3D Model to Fritzing part
Inkscape Scaling
Linear Voltage regulators
Searching for Terminal Block
Does anyone have a lithium battery with 3.7V 950mah?
GY-BME/P280 part
How to edit Part SIP-1A05 Reed Relay?
OrangePI 3 LTS Part request
How to set Transistor or component Characteristics
How to make a Fritzing part?
Define a partial circuit (Teilschaltung )
Looking for various parts for drone project!
Looking for Some Help with Custom PCB Design in Fritzing!
Can't edit labels on silk screen
Font issues when creating a new part
Ks0360 Keyestudio Sensor Shield V2 for BBC micro:bit
KMR 1.8 128*160 TFT SPI Fritzing File
I'm gonna attempt to make a "ESP8285 chip"
Fritzing file for simple tranformer
Lever Wire Connectors (assorted)
Please help with 4 parts Molex
ER-OLED024-2 OLED Display
[waveshare] solar power management module (D)
1/5 Autonomous Vehicle Circuit
MIC5504 sot23-5
Need to enlarge THT holes for 1/4'' connector
Cannot select Part/Edit (new part editor) to create a new part
Cant access parts editor
ESP32 Plus board
About the parts-submit category
Problems with LM2596 Layout
A bit lost and in need of help
Edit Breadboard Icon Failed
Fritzing Part BurrBrown / TI PGA2311P / 2310P
I'm looking for the Weact Studio STM32H743 Dev Board part
SCC-32 Motor Driver
Kamal Hinduja : How can I contribute to Fritzing (code, parts, translations)?
Texas Instruments BQ76940
(invalid) Need Quectel LC29H
Part for SHT30 (SHT3X-D1S)
ESP32-C6 Super Mini Part
Help me creating this TTL RS485 module
In need of Si4432 868MHz part for PCB!
ISO: Songle SRA-12VDC-CL PCB relay
DC-DC Buck-Boost Converter (CN3903)
12V Lead Battery
Looking for a HY-SRF05 Ultrasonic Range Finder
Creating a new part does not work
Fritzing part creator
Looking for LTC3260
Problems loading an svg into the editor?
Image disappears after creating it
Schematic part grid annoyance
Can the Arduino MKR Motor Carrier schematic be made?
Using transistors on veroboard in the breadboard section
Bug in PCB view of relay DS2Y-S-DC5V, a core part
Unexpected 2 pins connected on a part
Building custom parts library
Help on creating pololu motor shield drv8833 blackout
Fritzing for DFRobot UART MP3 Voice Module
Import self-made SVG for ESP32-C6-N8 Waveshare into Fritzing part editor
TSOP48 and PLCC32 SMD footprints
Unable to create a new part?
TM1637 - 4 digits 7 Segment Display
Cherry MX Blue part
P82B715 2-bit bidirectional 3- to 12-V 400-kHz I2C/SMBus buffer/cable extender
NUCLEO Card H755ZI-Q
Parts editor svg gets distorted
Has anyone made board Romeo from DFRobot?
Arduino MKR ENV Shield
Simple 12v Bulb Part?
Camper/Caravan/Solar Wiring
Part file for 7-pin OLED
Creating a simple part
Generic ICs with oblong/rectangular pads?
Prototype Screw/Terminal Block Shield Board Kit for Arduino MEGA 2560
How do i make my components smaller without breaking it?
Fritzing SVG dimension rules
NXP Semiconductor NX3DV42, SOT1160-1
Saving a drawing with the fritzing extension
Fritzing PCB for MetroM0 Express
SCD30 CO2 + temperature + humidity sensor
Grove - Temperature&Humidity Sensor (DHT11)
Esp-wroom-32d - firebeetle
New parts added
Trying to create a prototype part with a "breadboard" element
Fritzing-Schematic an Inkscape extension - released
(Duplicate) Deneyap Board fritzing part is ready
How do I connect the ground, vcc, and reset pins to the same pin in the schematic?
"Deneyap Mini" Fritzing Part
Need help for part help of EL357N SMD Optocoupler
Fritzing components Temperature and Humidity sensors SHT35-D TSYS01 HDC1010 ( closed cube )
Help With Part ESP32 S3 DEV KIT N8R8
How to make a part "flipable"
PCB Parts Editing
Created part has some pads that don't work in Breadboard View
NPN Transistor Pin Numbers
FC-51 Infrared Obstacle Avoidance Proximity Sensors Module
KF-301 Relay Request
Part editor dragging disabled
Help with building HmIP-MOD-OC8
Need Help - Keys L298P
Fritzing Part Creation - Chapter2 - Inkscape Basic
Learning how to draw in Inkscape - basics.
0:00 Overview
0:41 Drawing with Inkscape
0:53 Document Properties
1:35 Grids
2:24 XML Editor box
2:45 Fill and Stroke box
2:57 Transform box
3:09 Selecting shapes
3:27 Drawing rectangle
5:29 Drawing circle
6:37 Drawing lines
7:26 Resize page
8:13 XML Editor
Fritzing Part Creation - Chapter3 - Inkscape Advanced Essentials
Learning how to draw in Inkscape - more features.
0:00 Overview
0:16 Select object with cursor and XML Editor
3:34 Manipulate special PDF’s in Inkscape
4:33 XML Editor - Direct drawing manipulation
6:05 XML Editor - Making group, moving object, changing layer height
7:27 Cursor - Changing layer height
8:21 Ruler
9:07 Grids
9:28 Snap selection
10:16 Drawing origin
New Part CJMCU-811 Part
Part creation for CAN module Niren
Dimmer switch - Thyristor Robotdyn TRIAC
New part problems :inkscape & fritzing
74LS IC's i need help for these parts
DC-DC Converter with XL4016
Part request: 5 way tactile switch 10x10mm
INA125P Instrumentation Amplifier
Part for new SBC
Modem GSM/GPRS Ai A6
Does someone has the MAX471 current sensor module Fritzing Part?
4 position linear switch request (pretty please)
Nice piece of work...unless you need to create special parts
Remove transistor leg
Making a SK6812 LED Part
2KPB06M bridge rectifier
PCB component layer names
Gear motor problem
7 segment display with 2 dp and 14 pins THT
"Show in Folder" doesn't show
Want to create a custom part for my design but cant
Request Part: YK04 RF Receiver Module
Ventilator controller in progress, looking messy
Running into two issues using Fritzing, one with custom PCBs, and one with package type
RS PRO, x Way PCB Terminal Block
MiniSense 100 - Oximeter - Max30205
Howto create Custom part (pot)
New Board Request:
Lego Mindstorm EV3
Request - Adafruit Buzzer 5V - Breadboard friendly
Fritzing beginner
Elegoo 2.8" Touch TFT
Sketch review - USB connector and mounting holes
Positioning the Arduino headers on a PCB board
How to build my IC (4-bit counter SN7475)?
Is the TSR 1-2450 in the Parts Catalog?
DB37 Female connector
How does parts creation get started
Issue with custom created fritzing part
A4988 Stepper Motor Driver Carrier
Importing SVG format to part editor
Looking for DM860A Stepper Motor Driver from Longs Motors Nema 23 Motor 1600 oz-in
DFRobot ROMEO V2 and ROMEO BLE - CONVERT PROBLEM
RDM6300 RFID module
Set IC Dimensions
Rotary micro switch
How can I find Bipolar Junction Transistor (BJT)?
How add mcp2515
Adding own editted part to origianal drawings
How to make component holes closer together
Robo RIO hardware layout?
Fritzing and a 3d scan
APA-102-2020 - the ultimate smd addressable led
NodeMcu V3 parts library
Parts editor is difficult to understand
Designing Components for Fritzing
Creating a new part
Minature Thermocouple to PCB connector. How Do I Make It?
Fritzing Part Creation - Chapter4 - Inkscape Advanced Extras
Learning how to draw in Inkscape - extra tricks to make parts.
0:00 Overview
0:30 Assemble large part
0:57 Using sourced image for non critical part view
1:50 Image from special PDF
3:27 Image from photo
6:30 Inkscape extra tools
Fritzing Part Creation - Chapter5 - PCB View
Drawing for PCB view, and checking outputs.
Note : The contact pad size used in this video is an example, use the applicable size for your application.
0:00 Overview
1:27 XML group format for PCB view
2:55 Correcting svg drawn with Adobe Illustrator
3:39 Unknown XML groups
3:51 SMD XML group format
4:20 Separate XML groups
4:22 Duplicated pads in both copper groups
4:49 Holes in PCB
5:31 Correct XML group format
5:52 Making an IC from scratch - Drawing
19:09 Making a hole in PCB
20:45 Add svg to part in Fritzing
21:04 Assign pins
21:48 Export gerber
22:06 Checking gerber with Gerbv
22:59 Checking dimensions in Gerbv
23:33 Check drill.txt file
24:44 Notes
Fritzing Part Creation - Chapter5.5 - PCB View Addendum
Addendum that covers pin contact size, Fritzing Edit problem, and auto pin assignment in Fritzing.
The generic IC in CORE bin didn’t like the PCB svg, which is odd because I’ve made part views from scratch and there hasn’t been any problems, so I’ve supplied a work around by using another DIP16 part which works fine.
0:00 Overview
0:11 Correction to the correct THT hole size
0:34 Generic IC was faulty, so redoing it with a good IC
2:45 Auto pin allocation - using “pin” auto assignment
Fritzing Part Creation - Chapter6 - Schematic View
It’s rare that you’ll have to make a schematic part from scratch, as they are so generic you could just use one from another part, but there are lots of tips in the video for things to look out for.
0:00 Overview
0:16 Making a SCH part from scratch
0:41 Drawing part with Inkscape
4:48 Load new SCH svg to part
5:36 Assign pins
6:02 Fritzing crash - my Fritzing doesn’t crash if you edit a part on a blank Fritzing
6:26 Resume after restart
6:34 Auto assign pins in Inkscape
7:45 Load new SCH svg to part
8:07 Assign pin end with compass points
9:13 Add text in Inkscape
9:20 Reset “Child” of “Parent”
10:03 Fonts - templates download - font setup
11:10 Adding text
13:56 Grouping - “transform” problems can be fixed by ungroup then group
14:52 Load new SCH svg to part
15:07 Fix font size by removing px in XML with Wordpad
16:34 Checking part - assign pins
17:10 Problems - not snapping to grid - pin colour indicator - pin tip box
Fritzing Part Creation - Chapter7 - Breadboard View
0:00 Overview of part drawing
0:45 Real world parts, Vs artificial parts
2:53 Drawing part with Inkscape
17:15 Add text in Inkscape - convert text to path
18:25 Auto assign pins in Inkscape
20:23 Load new BB view svg to part
20:58 Crash
21:21 Test part in Fritzing
21:39 Quick overview of modifying LED with bendable legs
Fritzing Part Creation - Chapter8 - Metadata
0:00 Overview
0:05 Icon
0:38 Metadata and effect in Inspector
5:11 Connectors
6:42 Metadata Family
8:35 Full part check - connection, drill, gerber check
Fritzing Part Creation - Chapter9 - Using Photo and PDF for Parts
Generally not recommended, except for one-off parts.
0:00 Overview
0:20 Photo to part using Inkscape
1:44 Import into Inkscape
2:25 Trace to bitmap
4:05 Manipulate object
5:46 Adding connector pins
11:25 Load new BB view svg to part
12:22 Assign pins
13:46 Checking part
14:16 Other views
15:12 Photo Vs drawing part - photo part problems
16:32 PCB Module example
18:25 2nd PCB Module example
20:06 Special PDF to drawing using Inkscape
My high speed part mod video.
Note : It’s quicker to get an individual svg by right-click/Edit the part and File/Show in Folder.
Extra instructional videos
Making a custom PCB shape
EagleCAD to Fritzing part
Using Fritzing - Advanced Tips & Tricks - pt1
Breadboard View
0:00 Intro
0:18 Inspector doesn’t work
0:38 Search bar
1:17 Getting parts from sketch
1:38 Loading parts into Bin
1:49 Pin indicator colours
2:14 Wire doesn’t connect in Breadboard view
2:37 Fritzing BB view Vs Real world
3:32 Special items for BB view
4:41 Part Labels and fudging a part quickly
5:22 Manipulating parts and their connections
5:49 Curved wires
6:03 Orienteering parts
6:09 Selecting parts
6:29 Wire colour
6:36 Changing view
6:50 Laying out BBs
7:06 Snapping to grid
Using Fritzing - Advanced Tips & Tricks - pt2
Schematic View
0:00 Intro
0:06 Beginner mistakes - Junctions and manipulating lines
2:24 No 4 point junctions
2:50 Pins don’t auto connect
3:16 Special items for SCH view
3:53 SCH layout protocols
4:27 Selecting parts
4:35 Live connected views
6:30 Solid connections Vs ratsnest lines
8:12 Fritzing views
Using Fritzing - Advanced Tips & Tricks - pt3
PCB View
0:00 Intro
0:38 Parts don’t fit
1:14 Drawing traces - selecting sides
1:59 Trace width
2:30 PCB modern trace practises
2:42 Drawing traces - shortcut keys
3:39 Moving parts
4:36 PCB layout tips
5:31 Laying out trace tips
5:59 Special PCB items
7:53 Ground Fill - Copper Fill Vs Ground Fill
9:59 Autorouter
10:51 Extra special items
11:03 Dimension tips
11:55 PCB Sticky
12:05 Track width calc and 2 size trace
12:26 DRC Design Rules Check
13:24 Checking your PCB - Gerbers
14:31 Export options
14:48 References
15:00 Special functions
Using Fritzing - Advanced Tips & Tricks - pt4
Parts & Fritzing Editor
0:00 Intro
0:58 Help finding a part
1:17 Searching for parts
4:04 Fritzing Part Editor
4:18 Fritzing usage
4:35 PCB footprint - swapping svg’s
6:04 PCB footprint - editing svg’s
6:12 Breadboard graphics
6:37 Drawing basics
6:45 SCH view part - basics
7:23 PCB view parts - basics
8:32 BB view parts - basics
9:06 Tutorials
9:31 EagleCAD to Fritzing
Making Fritzing Parts Fast #1 - Breadboard pt1
0:00 Intro
0:41 Making breadboard view svg drawing
0:43 Setup Inkscape
1:39 Drawing PCB
2:14 Getting connector pin svg from Fritzing part
3:15 Modifying Fritzing part connector pin svg
5:01 Connector pin assign methods
5:44 Adding 2nd connector pin set and grouping
6:39 Assign connector pin using XML ID name
7:02 Paste and position connector pins into breadboard svg
7:40 Adding mount pins
7:52 Preliminary svg test in Fritzing
8:39 Bringing svg into Fritzing part with Part Editor
9:02 Checking pin assignment
9:25 Finishing connector pin assignment in Inkscape
9:36 Quicker bulk connector pin assignment in Inkscape
Making Fritzing Parts Fast 2 - Breadboard pt2
0:00 Intro
0:21 Getting components off the Fritzing part svg using Inkscape
1:37 Modifying components and positioning them
2:36 Making simple components
4:09 Getting logos
4:47 Text
4:58 Text method #1, and manipulating text
7:29 Duplicating and moving text
8:13 Editing text words
8:32 Duplicating and moving text groups
9:20 Text method #2
9:57 Re-order XML table, make breadboard group,
10:16 Resize page to drawing
10:34 Text method #1 - XML code correction, ie, removing “px”
11:35 Saving your svg
11:42 Loading your svg to a Fritzing part, and checking it
12:05 Setting wire anchor point
12:28 Assigning pins manually in Fritzing edit
13:03 No Inkscape pin id, so pins can be assigned in Fritzing
13:27 Adding more pins in Fritzing Edit
13:35 Internal part connections
13:48 Changing part icon
13:52 Saving as new part
14:19 Testing your part in sketch
