TDS Meter Part Fritzing
Not an overly useful part. There is no indication (such as a web site) of which tds meter it is supposed to be (there are several available but I don’t see one that matches this.) Breadboard has poor font sizes and pins that don’t align to the 0.1in grid. The family is left at Generic IC and thus Inspector will replace the part with another IC if clicked (and it will probably be hard to get back to what you had from there.)
schematic lacks terminalIds so the wires connect to the center of the pin instead of the end
and pcb is left at a generic IC instead of being either suppressed as not useful or with a silkscreen that defines the outline of the board (in case you wanted to mount it on a pcb.)
These two tutorials on making parts may help
Much the same issues in your relay part as this one. There are also existing relay modules available.
