RS PRO, x Way PCB Terminal Block
I’d probably start with the 2 position ones as being easiest (the 8 can be produced by copy/paste of the 2 pin version.) I see there is a footprint of some kind available which may make things easier, because there doesn’t look to be a data sheet available. These two sets of tutorials are probably a good place to start from the Fritzing end:
