For starters it would have been much easier to just supply the requested information and I would have made a part for you. That said, your part has a number of problems. FritzingCheckPartw.py has this to say about it:
$ FritzingCheckPartw.py part.prefix000000111222333_d2662e92c42047e15e4e04a8ff374202_1.fzp
**** Starting to process file Startup, no file yet
**** Starting to process file part.prefix000000111222333_d2662e92c42047e15e4e04a8ff374202_1.fzp
**** Starting to process file svg.breadboard.prefix000000111222333_41ae834d6ea14927070202f126ecf6ce_1_breadboard.svg.bak
**** Starting to process file svg.schematic.prefix000000111222333_41ae834d6ea14927070202f126ecf6ce_1_schematic.svg.bak
**** Starting to process file svg.pcb.prefix000000111222333_41ae834d6ea14927070202f126ecf6ce_1_pcb.svg.bak
File
‘part.prefix000000111222333_d2662e92c42047e15e4e04a8ff374202_1.fzp.bak’
This is a through hole part as both copper0 and copper1 views are present.
If you wanted a smd part remove the copper0 definition from line 41
Modified 4: File
‘svg.breadboard.prefix000000111222333_41ae834d6ea14927070202f126ecf6ce_1_breadboard.svg.bak’
At line 5
ReferenceFile
‘SVG_LC29H_Breadboard.svg’
doesn’t match input file
‘prefix000000111222333_41ae834d6ea14927070202f126ecf6ce_1_breadboard.svg’
Corrected
Modified 1: File
At line 4693
Removed px from font-size leaving 4.37549
Modified 1: File
At line 4694
Modified 1: File
At line 4723
Removed px from font-size leaving 6.56323
Modified 1: File
At line 4724
Modified 1: File
At line 4745
Removed px from font-size leaving 5.33333333
Modified 4: File
‘svg.schematic.prefix000000111222333_41ae834d6ea14927070202f126ecf6ce_1_schematic.svg.bak’
At line 5
ReferenceFile
‘LC29H_detailed_schematic.svg’
‘prefix000000111222333_41ae834d6ea14927070202f126ecf6ce_1_schematic.svg’
Corrected
Modified 4: File
‘svg.pcb.prefix000000111222333_41ae834d6ea14927070202f126ecf6ce_1_pcb.svg.bak’
At line 5
ReferenceFile
‘ADXL335_v13_pcb.svg’
‘prefix000000111222333_41ae834d6ea14927070202f126ecf6ce_1_pcb.svg’
Corrected
Modified 3: File
At line 9
Silkscreen, converted stoke from white to black
Modified 3: File
At line 10
Modified 3: File
At line 11
Modified 3: File
At line 12
Modified 3: File
At line 13
Modified 3: File
At line 14
Modified 3: File
At line 15
Modified 3: File
At line 16
Modified 3: File
At line 17
Modified 3: File
At line 18
Modified 3: File
At line 23
Modified 3: File
At line 24
Modified 3: File
At line 25
Modified 3: File
At line 26
Modified 3: File
At line 27
Modified 3: File
At line 28
Modified 3: File
At line 29
Modified 3: File
At line 30
Modified 3: File
At line 31
Modified 3: File
At line 32
Modified 3: File
At line 33
Modified 3: File
At line 34
Modified 3: File
At line 35
Modified 3: File
At line 36
Modified 3: File
At line 37
Modified 3: File
At line 38
Modified 3: File
At line 39
Modified 3: File
At line 40
Modified 3: File
At line 41
Modified 3: File
At line 42
Modified 3: File
At line 43
Modified 3: File
At line 44
Modified 3: File
At line 45
Modified 3: File
At line 46
Modified 3: File
At line 47
Modified 3: File
At line 48
Modified 3: File
At line 49
Modified 3: File
At line 50
Modified 3: File
At line 51
Modified 3: File
At line 52
Modified 3: File
At line 53
Modified 3: File
At line 54
Modified 3: File
At line 55
Modified 3: File
At line 56
Modified 3: File
At line 57
Modified 3: File
At line 58
Modified 3: File
At line 59
Modified 3: File
At line 60
Modified 3: File
At line 73
Modified 3: File
At line 74
Modified 3: File
At line 75
Modified 3: File
At line 76
Modified 3: File
At line 77
Modified 3: File
At line 78
Modified 3: File
At line 79
Warning 6: File
At line 2
ReferenceFile name
‘ADXL335_v13.fzp’
Doesn’t match fzp filename
‘prefix000000111222333_d2662e92c42047e15e4e04a8ff374202_1.fzp’
Warning 36: File
Connector0 doesn’t exist. Connectors should start at 0
Warning 35: File
Connector0 doesn’t exist when it must to stay in sequence
Warning 32: File
At line 3
Scale is not the desirable 1/1000 ratio from width/height to
viewBox width/height.
Warning 23: File
At line 4724
Key -inkscape-font-specification
value OCRA is invalid and has been deleted
Warning 32: File
At line 3
Warning 32: File
At line 3
Error 69: File
At line 22
Error 69: File
At line 11
Error 77: File
At line 27
terminalId connector11terminal can’t be a g as it won’t work.
Error 77: File
At line 30
terminalId connector10terminal can’t be a g as it won’t work.
Error 77: File
At line 33
terminalId connector9terminal can’t be a g as it won’t work.
Error 77: File
At line 36
terminalId connector8terminal can’t be a g as it won’t work.
Error 77: File
At line 87
terminalId connector12terminal can’t be a g as it won’t work.
Error 77: File
At line 138
terminalId connector13terminal can’t be a g as it won’t work.
The terminalIds being groups is the major problem it causes this:
In theory Fritzing 1.0.5 is supposed to correct this, but it doesn’t appear to work if the terminalId is a group and thus connects to the center of the pin rather than the end as it should. The following two tutorials may be of assistance if you want to make parts (FritzingCheckPart.py and Randy’s Inkscape schematic extension which is the preferred way to make schematics are covered in mine.)
