It looks like you have a corrupted part in your user directories (I don’t thing it has anything to do with the new part which loads correctly for me.) If you don’t have a lot of parts in your mine parts bin this should fix the problem by clearing the user directories (but will delete all your imported parts!) I would expect the same will happen if you just start Fritzing without trying to load the new part though (since I don’t think it has anything to do with the new part.) For me (on Fritzing 1.0.4 on Win10) the part loads fine with no errors.
"There are two user directories (with your parts and the parts database) which don’t get touched during an install (to not affect your sketches during upgrades). On Windows they are in
c:\users\username\AppData\Fritzing\roaming\Fritzing (which is a hidden directory so you need to enable hidden directories in explorer) and
c:\Users\username\My Documents\Fritzing (where username is your windows id)
If you don’t have any parts or sketches you want to keep you can just delete those two directories and Fritzing will recreate them, or you can move them aside by renaming them if you want to keep something in them.
linux
~/Documents/Fritzing/parts
~/.config/Fritzing
Mac
/Users/username/Documents/Fritzing/parts
~/.config/Fritzing"
This pair of parts making tutorials cover current versions of Fritzing (although as you will discover making parts is complex!)
If you run in to troubles building the part I can make one for you.
