vanepp
March 12, 2022, 6:19pm
2
Parts editor can’t currently do this. You would need to edit the pcb svg for the part with a svg editor such as Inkscape to increase the hole size. These two sets of part making tutorials may help
NEW FASTER PART MAKING VIDEOS AT THE BOTTOM-Fritzing Parts Fast
ADVANCED FRITZING USER TIPS & TRICKS VIDEOS AT THE BOTTOM-Fritzing Adv Tips & Tricks
A series of part creation videos - I’m not an expert, but there was nothing else around at the time.
Use 1080p HD fullscreen to see details clearly - use gear symbol bottom right -.
Recorded slowly for older people, so select a higher speed if it’s too slow.
P.S. - Sorry about the voice/sound
Fritzing Part Creation - Chapter1 - New Part …
Someone in this forum post
requested help to fix up a part. So while doing that I decided to record what I needed to do in order to fix the part to provide a tutorial to create new / fix broken parts. If you start from the Tarjeta S4A EDU.fzpz file posted in the above thread, you should be able to recreate my improved part posted in the same thread. I started by loading the original part in to Fritzing, that indicates breadboard is (at first look anyway) pretty good, but schematic and pcb are…
or if you supply the .fzpz file for the part you are using I can modify the hole size (it is a trivial change for me.)
