Fritzing PART CREATION Video Tutorial Series
Fritzing Part Creation - Chapter3 - Inkscape Advanced Essentials
Learning how to draw in Inkscape - more features.
0:00 Overview
0:16 Select object with cursor and XML Editor
3:34 Manipulate special PDF’s in Inkscape
4:33 XML Editor - Direct drawing manipulation
6:05 XML Editor - Making group, moving object, changing layer height
7:27 Cursor - Changing layer height
8:21 Ruler
9:07 Grids
9:28 Snap selection
10:16 Drawing origin
New Part CJMCU-811 Part
Dimmer switch - Thyristor Robotdyn TRIAC
Part creation for CAN module Niren
New part problems :inkscape & fritzing
74LS IC's i need help for these parts
DC-DC Converter with XL4016
Part request: 5 way tactile switch 10x10mm
INA125P Instrumentation Amplifier
Part for new SBC
Modem GSM/GPRS Ai A6
Does someone has the MAX471 current sensor module Fritzing Part?
4 position linear switch request (pretty please)
Nice piece of work...unless you need to create special parts
Remove transistor leg
Making a SK6812 LED Part
A discussion of future direction
2KPB06M bridge rectifier
PCB component layer names
Gear motor problem
7 segment display with 2 dp and 14 pins THT
"Show in Folder" doesn't show
Want to create a custom part for my design but cant
Request Part: YK04 RF Receiver Module
Ventilator controller in progress, looking messy
Running into two issues using Fritzing, one with custom PCBs, and one with package type
RS PRO, x Way PCB Terminal Block
MiniSense 100 - Oximeter - Max30205
Howto create Custom part (pot)
New Board Request:
Lego Mindstorm EV3
Request - Adafruit Buzzer 5V - Breadboard friendly
Fritzing beginner
Elegoo 2.8" Touch TFT
Sketch review - USB connector and mounting holes
Positioning the Arduino headers on a PCB board
How to build my IC (4-bit counter SN7475)?
Is the TSR 1-2450 in the Parts Catalog?
Add enter-able property box for parts in Inspector
DB37 Female connector
How does parts creation get started
Issue with custom created fritzing part
A4988 Stepper Motor Driver Carrier
Importing SVG format to part editor
Looking for DM860A Stepper Motor Driver from Longs Motors Nema 23 Motor 1600 oz-in
DFRobot ROMEO V2 and ROMEO BLE - CONVERT PROBLEM
RDM6300 RFID module
Set IC Dimensions
Rotary micro switch
How can I find Bipolar Junction Transistor (BJT)?
How add mcp2515
Adding own editted part to origianal drawings
How to make component holes closer together
Robo RIO hardware layout?
Fritzing and a 3d scan
APA-102-2020 - the ultimate smd addressable led
NodeMcu V3 parts library
Parts editor is difficult to understand
Designing Components for Fritzing
Creating a new part
Minature Thermocouple to PCB connector. How Do I Make It?
