A google search of the form “fritzing part fritzing part MIC5504 sot23-5” which is the best way to find available parts turns up this which may do for the footprint at least.
yeah, i always do the google search including word ‘fritzing’ to find parts first, however nothing there.
I can try use ‘sparkfun voltage regulator’ sot23-5 but pinout and label not correct
For 1 or 2 parts it is not worth learning part creation, but you are requesting enough parts that it is likely worthwhile to learn to do it for yourself. The following two tutorials explain how (you may have already seen them, they get posted a lot!):
thankyou, yes i have attempted to make fritzing parts maybe 3-4 times, but i fail due to complexity and confusion. I will look at the videos and try and make a part again.
I would suggest reading my tutorial as well. Part making is complex and you need to understand how it all inter relates to be successful. Parts editor has a number of limitations which is why I rarely use it at all.
