Hi there everyone!
I’m trying to modify a fzz file I found online to match my dfrobot firebeetle but I’m having a hard time getting it to work on Fritzing.
I’ve modified all the svg files and the part.xxx.fz file and still get errors while trying to use the part.
The error says something on not finding a file inside the package but they are all there!
The format of your fzpz file is incorrect (the part is as well, but the .fzpz file is what is stopping the load!) It currently looks like this:
and it needs to look like this:
with only the files circled in red in the fzpz file at the top level in order to load. That said, the part is incorrect in that both schematic and pcb have problems with connectors.
Hi peter, many thanks for the answers, I’ll take a look at them and will try to fix them later in the day but I do confess I’m a newbie and it hasn’t been easy try to mod an existing design.
As for the original firebeetle part, mine has a ESP32-WROOM-32D chip and the pinout is slightly different. I’ve searched everywhere for a similar board but none that I found is a match.
I’m adding links to the board + dfrobot website below to illustrate the differences
I think this board is a little too complex to try modifying without being experienced in making parts, so I am in the process of doing one. So far I have started on breadboard by using the jpeg image above imported in to Inkscape like this:
there is the base rectangle and the mounting holes and some of the parts (but not yet the connectors) in this svg (here with the jpeg moved to show the board and parts so far alone):
Thanks Peter!
I’ll watch the tutorials for sure as I want to be able to create/mod parts on my own at some point and hopefully even contribute back! (Even though I’m fully aware it will still take some time to get there )
Also, many many thanks for taking the time to look into my problem, answer me and help me with the schematics. It is much appreciated!
OK here is a new part for this board. As usual the mounting holes are only on silkscreen, if you want the mounting holes drilled you need to drag a hole from core parts over the circle in silkscreen and set the size (probably 2mm.)
So I like to try adding pads on my fritzing PCB. First I thought it could be a good Idea to edit FireBeetle-ESP32-E-tht_1_pcb.svg and adjust the THT connectors with longer pads as described in https://forum.fritzing.org/t/generic-ics-with-oblong-rectangular-pads/6140/14 but the needed pads are longer than the board itself. So I would have to make the component for the PCB bigger than it is in nature. An other approach would be to add simply pads on the fritzing PCB view:
Yes this should work fine. DRC will likely complain because there is copper overlap but the pads will work in the end as copper is copper on the board.
I have to correct myself or be a bit more precise: The old version 1 Firebeetle has no castellated holes, only the new one, Version 2 with an ESP32-E, see https://www.dfrobot.com/product-2195.html. Unfortunately the pinout is completely different in the new version and the old Fritzing part has to be modified.
