Here is another view of the problem. I ran the .fzp file through FritzingCheckPart.py and the output is as bad as I expected, but will tell you all that is wrong. I started at the Errors section (there are probably as many warnings before this ) There are buses defined in the original part that aren’t correct in the final part, but that won’t cause the problem you are seeing (those are caused by the missing connectors in schematic.) The terminalId complaints will only cause the connection in the middle of the pin not actually break things, these however will cause the problem you are seeing in schematic:
Error 18: File
‘part.prefix0000_c103347c78f2dbe1f405265797e9dadc_21.fzp.bak’
Connector connector49pin is in the fzp file but not the svg file. (typo?)
connector49pin is defined in the fzp file but not the schematic svg and that will cause the yellow/red/blue rectangle and the “route the wire to the middle of the part” that you are seeing. The correct pins should have been there in the original file so I don’t know what happened to them.
$ FritzingCheckPartw.py part.prefix0000_c103347c78f2dbe1f405265797e9dadc_21.fzp
**** Starting to process file part.prefix0000_c103347c78f2dbe1f405265797e9dadc_21.fzp
**** Starting to process file svg.breadboard.prefix0000_c794d5c3e53a6462c5997d43c705ec2f_1_breadboard.svg.bak
**** Starting to process file svg.schematic.prefix0000_c794d5c3e53a6462c5997d43c705ec2f_1_schematic.svg.bak
**** Starting to process file svg.pcb.prefix0000_c794d5c3e53a6462c5997d43c705ec2f_1_pcb.svg.bak
File
If you wanted a smd part remove the copper0 definition from line 48
Modified 4: File
‘svg.breadboard.prefix0000_c794d5c3e53a6462c5997d43c705ec2f_1_breadboard.svg.bak’
Error 53: File
At line 1292
Bus nodeMember connector377 does’t exist
Error 53: File
At line 1293
Bus nodeMember connector378 does’t exist
Error 69: File
‘svg.schematic.prefix0000_c794d5c3e53a6462c5997d43c705ec2f_1_schematic.svg.bak’
At line 20
Error 77: File
At line 21
terminalId connector238terminal can’t be a g as it won’t work.
Error 77: File
At line 22
terminalId connector239terminal can’t be a g as it won’t work.
Error 77: File
At line 33
terminalId connector240terminal can’t be a g as it won’t work.
Error 77: File
At line 44
terminalId connector241terminal can’t be a g as it won’t work.
Error 77: File
At line 55
terminalId connector243terminal can’t be a g as it won’t work.
Error 77: File
At line 57
terminalId connector242terminal can’t be a g as it won’t work.
Error 77: File
At line 68
terminalId connector269terminal can’t be a g as it won’t work.
Error 77: File
At line 79
terminalId connector268terminal can’t be a g as it won’t work.
Error 77: File
At line 90
terminalId connector267terminal can’t be a g as it won’t work.
Error 77: File
At line 101
terminalId connector266terminal can’t be a g as it won’t work.
Error 77: File
At line 102
terminalId connector265terminal can’t be a g as it won’t work.
Error 77: File
At line 103
terminalId connector264terminal can’t be a g as it won’t work.
Error 77: File
At line 104
terminalId connector263terminal can’t be a g as it won’t work.
Error 77: File
At line 105
terminalId connector262terminal can’t be a g as it won’t work.
Error 77: File
At line 106
terminalId connector53terminal can’t be a g as it won’t work.
Error 77: File
At line 107
terminalId connector52terminal can’t be a g as it won’t work.
Error 77: File
At line 108
terminalId connector51terminal can’t be a g as it won’t work.
Error 77: File
At line 109
terminalId connector50terminal can’t be a g as it won’t work.
Error 77: File
At line 110
terminalId connector49terminal can’t be a g as it won’t work.
Error 77: File
At line 113
terminalId connector235terminal can’t be a g as it won’t work.
Error 77: File
At line 115
terminalId connector234terminal can’t be a g as it won’t work.
Error 77: File
At line 116
terminalId connector345terminal can’t be a g as it won’t work.
Error 77: File
At line 117
terminalId connector346terminal can’t be a g as it won’t work.
Error 77: File
At line 118
terminalId connector347terminal can’t be a g as it won’t work.
Error 77: File
At line 119
terminalId connector348terminal can’t be a g as it won’t work.
Error 77: File
At line 120
terminalId connector349terminal can’t be a g as it won’t work.
Error 77: File
At line 121
terminalId connector350terminal can’t be a g as it won’t work.
Error 77: File
At line 122
terminalId connector351terminal can’t be a g as it won’t work.
Error 77: File
At line 123
terminalId connector352terminal can’t be a g as it won’t work.
Error 77: File
At line 124
terminalId connector353terminal can’t be a g as it won’t work.
Error 77: File
At line 125
terminalId connector354terminal can’t be a g as it won’t work.
Error 77: File
At line 126
terminalId connector355terminal can’t be a g as it won’t work.
Error 77: File
At line 127
terminalId connector356terminal can’t be a g as it won’t work.
Error 77: File
At line 128
terminalId connector357terminal can’t be a g as it won’t work.
Error 77: File
At line 129
terminalId connector358terminal can’t be a g as it won’t work.
Error 77: File
At line 130
terminalId connector359terminal can’t be a g as it won’t work.
Error 77: File
At line 131
terminalId connector360terminal can’t be a g as it won’t work.
Error 77: File
At line 132
terminalId connector256terminal can’t be a g as it won’t work.
Error 77: File
At line 133
terminalId connector236terminal can’t be a g as it won’t work.
Error 77: File
At line 134
terminalId connector254terminal can’t be a g as it won’t work.
Error 77: File
At line 151
terminalId connector344terminal can’t be a g as it won’t work.
Error 77: File
At line 160
terminalId connector0terminal can’t be a g as it won’t work.
Error 77: File
At line 168
terminalId connector361terminal can’t be a g as it won’t work.
Error 77: File
At line 169
terminalId connector362terminal can’t be a g as it won’t work.
Error 77: File
At line 170
terminalId connector363terminal can’t be a g as it won’t work.
Error 77: File
At line 171
terminalId connector364terminal can’t be a g as it won’t work.
Error 77: File
At line 172
terminalId connector365terminal can’t be a g as it won’t work.
Error 77: File
At line 173
terminalId connector366terminal can’t be a g as it won’t work.
Error 77: File
At line 174
terminalId connector367terminal can’t be a g as it won’t work.
Error 77: File
At line 175
terminalId connector368terminal can’t be a g as it won’t work.
Error 77: File
At line 176
terminalId connector369terminal can’t be a g as it won’t work.
Error 77: File
At line 177
terminalId connector370terminal can’t be a g as it won’t work.
Error 77: File
At line 178
terminalId connector371terminal can’t be a g as it won’t work.
Error 77: File
At line 179
terminalId connector372terminal can’t be a g as it won’t work.
Error 77: File
At line 180
terminalId connector373terminal can’t be a g as it won’t work.
Error 77: File
At line 191
terminalId connector374terminal can’t be a g as it won’t work.
Error 77: File
At line 202
terminalId connector375terminal can’t be a g as it won’t work.
Error 77: File
At line 213
terminalId connector376terminal can’t be a g as it won’t work.
Error 77: File
At line 215
terminalId connector377terminal can’t be a g as it won’t work.
Error 77: File
At line 219
terminalId connector237terminal can’t be a g as it won’t work.
Error 77: File
At line 252
terminalId connector378terminal can’t be a g as it won’t work.
Error 77: File
At line 253
terminalId connector257terminal can’t be a g as it won’t work.
Error 77: File
At line 284
terminalId connector261terminal can’t be a g as it won’t work.
Error 18: File
Connector connector1terminal is in the fzp file but not the svg file. (typo?)
svg svg.schematic.prefix0000_c794d5c3e53a6462c5997d43c705ec2f_1_schematic.svg.bak
Error 18: File
Connector connector2terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector3terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector4terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector5terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector6terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector7terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector8terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector9terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector10terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector11terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector12terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector13terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector14terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector15terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector46terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector47terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector48terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Error 18: File
Connector connector50pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector51pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector52pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector53pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector234pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector235pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector236pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector238pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector239pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector240pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector241pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector242pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector243pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector254pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector255terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector256pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector257pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector258terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector259terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector260terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector261pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector262pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector263pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector264pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector265pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector266pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector267pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector268pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector269pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector343terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector344pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector345pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector346pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector347pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector348pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector349pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector350pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector351pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector352pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector353pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector354pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector355pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector356pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector357pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector358pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector359pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector360pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector361pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector362pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector363pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector364pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector365pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector366pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector367pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector368pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector369pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector370pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector371pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector372pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector373pin is in the fzp file but not the svg file. (typo?)
