hello ,vanepp
please , I want the parts in the pcb because i did not find it in the parts , which is (HR961160C )
I have project that i need quickly
vanepp
June 19, 2022, 3:58am
#3
This should do what you want.
HR961160C.fzpz (10.8 KB)
You should also look at learning to make parts (as you are asking for a lot of them.) For one or two parts it isn’t worth learning part making, for larger numbers it is worth spending the time. The following tutorials should help.
NEW FASTER PART MAKING VIDEOS AT THE BOTTOM-Fritzing Parts Fast
ADVANCED FRITZING USER TIPS & TRICKS VIDEOS AT THE BOTTOM-Fritzing Adv Tips & Tricks
A series of part creation videos - I’m not an expert, but there was nothing else around at the time.
Use 1080p HD fullscreen to see details clearly - use gear symbol bottom right -.
Recorded slowly for older people, so select a higher speed if it’s too slow.
P.S. - Sorry about the voice/sound
Fritzing Part Creation - Chapter1 - New Part …
Someone in this forum post
requested help to fix up a part. So while doing that I decided to record what I needed to do in order to fix the part to provide a tutorial to create new / fix broken parts. If you start from the Tarjeta S4A EDU.fzpz file posted in the above thread, you should be able to recreate my improved part posted in the same thread. I started by loading the original part in to Fritzing, that indicates breadboard is (at first look anyway) pretty good, but schematic and pcb are…
Hi all!
I have been working on an extension for Inkscape to create rectangular schematic symbol .svg files for use in Fritzing. I think I created a useful tool to speed up creation of schematic symbols, and now I want to share it with the community.
It’s available on github:
https://github.com/revolt-randy/Fritzing-Schematic-an-Inkscape-Extension.
To install:
In Inkscape, the edit menu → user preferences → system will have an option for ‘User extensions’ - allowing you to open the folder to…
