Hello together,
for my MicroPython project, I would like to use the Arduino Portenta H7 with Breakout board.
I use Fritzing 1.0.0 Beta in the Linux version.
As Newbe in Fritzing, I couldn’t find this breakout board in the library.
Is there an additional source for this Breakout board?
My focus is on the connector pinouts on page 10:
https://docs.arduino.cc/static/b642f2a6c5e5a1120f1e30da670837f7/ASX00031-datasheet.pdf
No 80 Pin IF’s or camera.
Thank you.
vanepp
July 11, 2023, 5:43pm
There is some (missing the two 80 pin connectors) fritzing part here
Would anyone be so kind to make a board file for the Arduino Portenta H7? I’ve been on the lookout in a Google search but sadly nothing comes up.
I can provide the images here.
Thank you. I really appreciate it!
[PortentaH7_white] !
it appears to be the H7 board only not the breakout board though, but may be able to do what you need.
Ok, Thanks for your support
vanepp
July 11, 2023, 6:44pm
#4
If the original won’t work it is possible (but a lot of work) to make a part for the breakout. I would rather not do that work if the original will do what you need.
Hello Peter,
for the first tests will be the H7 board ok. For the planned circuit, I have to use the breakout board. Do you have a tutorial, how I can learn to create own parts in fritzing?
vanepp
July 12, 2023, 3:02pm
#6
Yes. These two apply to current versions of Fritzing.
NEW FASTER PART MAKING VIDEOS AT THE BOTTOM-Fritzing Parts Fast
ADVANCED FRITZING USER TIPS & TRICKS VIDEOS AT THE BOTTOM-Fritzing Adv Tips & Tricks
A series of part creation videos - I’m not an expert, but there was nothing else around at the time.
Use 1080p HD fullscreen to see details clearly - use gear symbol bottom right -.
Recorded slowly for older people, so select a higher speed if it’s too slow.
P.S. - Sorry about the voice/sound
Fritzing Part Creation - Chapter1 - New Part …
Someone in this forum post
requested help to fix up a part. So while doing that I decided to record what I needed to do in order to fix the part to provide a tutorial to create new / fix broken parts. If you start from the Tarjeta S4A EDU.fzpz file posted in the above thread, you should be able to recreate my improved part posted in the same thread. I started by loading the original part in to Fritzing, that indicates breadboard is (at first look anyway) pretty good, but schematic and pcb are…
although as you will discover it is not easy.
vanepp
July 15, 2023, 1:03am
#7
This part should do what you want for the breakout board (since it seems unlikely that you would be successful in making one …)
arduino-portenta-h7-breakout.fzpz (28.6 KB)
Thank you Peter,
your support helps a lot.
