SR16 - Rotary switch 8 positions 1 pole
Previous work, similar parts
Rotary switch 12x1
Could not find a proper datasheet anywhere.
Here’s the producer’s website
We are a manufacturer of KLS7-SR16/16mm, exporter of KLS7-SR16/16mm made in China, get more KLS7-SR16/16mm suppliers, factories, wholesalers, distributors, companies from China on klsele.com.
DIP?
vanepp
April 24, 2024, 2:47am
2
This part should do what you want. There is a better data sheet here:
which is still poor but at least provides the pin out and a pcb recommendation.
rotary-switch-8pos-SR16A.fzpz (5.6 KB)
although the hole looks a little out of position with the 16mm circle in place it appears on the edge of the circle and is thus probably correct.
It would be best to print out the pcb footprint at 1:1 scale and compare it to a real part before ordering boards though.
Thank you so much!!!
How can I start to learn to design my own components?
vanepp
April 25, 2024, 10:51pm
4
These two tutorials cover the current version of Fritizng (although making parts is not at all easy!)
NEW FASTER PART MAKING VIDEOS AT THE BOTTOM-Fritzing Parts Fast
ADVANCED FRITZING USER TIPS & TRICKS VIDEOS AT THE BOTTOM-Fritzing Adv Tips & Tricks
A series of part creation videos - I’m not an expert, but there was nothing else around at the time.
Use 1080p HD fullscreen to see details clearly - use gear symbol bottom right -.
Recorded slowly for older people, so select a higher speed if it’s too slow.
P.S. - Sorry about the voice/sound
Fritzing Part Creation - Chapter1 - New Part …
