I created an svg file of a DS1307 RTC but when I import it into Fritzing it shows me this error. Could you help me?
There is something wrong with the breadboard svg file. Upload the .fzpz file of the broken part (upload is 7th icon from the left in the reply menu) and I will tell you what is wrong with it. If you donβt have a .fzpz file (which you may not given the part wonβt load) upload the breadboard svg file you have created (upload will also accept svg files as long as they are svg files!)
Hello Pierre,
Thank you for your reply, but it still shows an error.
Do you have the .fzpz file for the DS1307 RTC?
No I donβt have and there doesnβt appear to be a part for the DS1307 (there is an adafruit version, I donβt know if it is identical to this, in the Adafruit fritzing repository on github.) The problem with your svg (and why it wonβt load) is that it lacks any size information.
This is your svg displayed in Inkscape:
A correct breadboard svg looks like this:
Note the height and width (specified in inches or mm!) is needed so that Fritzing knows the real world size of the svg (px of no dimensions (which is the same as px) will cause scaling problems in Fritzing with modern Inkscapes.) Correcting that should enable your svg to load. You would then need to set connector numbers for each of the pins using parts editor (but that requires the correct number of pins in the .fzp file first as Parts editor canβt modify .fzp files at this time.) Here is a corrected version of your svg (although I donβt know if it is the correct size, you need to check the size of the module matches the module you have):
This is set to the correct scale for Fritzing and dimensioned in inches.
(to download the svg, right click on it and select βsave image asβ)
The following tutorial sets may help you in making parts (and if you run in to problems feel free to ask here!)
I lately learned there arenβt links to the videos in Old_Greyβs tutorial so you need to do a google search for the title and then they come up on YouTube.
Okay, thank you very much.
If you want me to make a part I can, but I would need the web site of the board you have. I canβt find any board that matches your image to get its size and connections.
Hello Peter,
Here are the dimensions: 4cm wide and 2.5cm high. The connectors are GND; VCC; SA; SCL; SQW.
Thank you Peter. β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β β
