PCB Parts Editor Pin Selection Not Working
I’ve been working on creating a 4 channel module 817 optocoupler. I was able to get the breadboard and schematic views to work, but for some reason I can only attach 18 out of 24 pins in the PCB view (parts editor). There are crosshairs that show up on the first 18, but after that I can’t get anymore to work. I started with the PCB SVG template and modified it in Inkscape using duplicate, so I’m not sure why some pins work and others do not.
Any help on this would be appreciated.
OPTOCOUPLER 4CH.fzpz (65.8 KB)
Your svg files are not in the correct format and lack layerIds. FritzingCheckPart.py reports the following errors on your part.
$ FritzingCheckPartw.py ‘part.OPTOCOUPLER 4CH_53b951f7e12564af33ab05b3ac698a0f_10.fzp’
**** Starting to process file part.OPTOCOUPLER 4CH_53b951f7e12564af33ab05b3ac698a0f_10.fzp
**** Starting to process file svg.breadboard.OPTOCOUPLER 4CH_2d7194bb8fdbc56d8a7c9b6c0e392041_3_breadboard.svg.bak
**** Starting to process file svg.schematic.OPTOCOUPLER 4CH_2d7194bb8fdbc56d8a7c9b6c0e392041_3_schematic.svg.bak
**** Starting to process file svg.pcb.OPTOCOUPLER 4CH_2d7194bb8fdbc56d8a7c9b6c0e392041_3_pcb.svg.bak
File
‘part.OPTOCOUPLER 4CH_53b951f7e12564af33ab05b3ac698a0f_10.fzp.bak’
If you wanted a smd part remove the copper0 definition from line 50
Modified 4: File
‘svg.breadboard.OPTOCOUPLER 4CH_2d7194bb8fdbc56d8a7c9b6c0e392041_3_breadboard.svg.bak’
At line 4
ReferenceFile
‘OPTOCOUPLER X4.svg’
doesn’t match input file
‘OPTOCOUPLER 4CH_2d7194bb8fdbc56d8a7c9b6c0e392041_3_breadboard.svg’
Corrected
Modified 4: File
‘svg.schematic.OPTOCOUPLER 4CH_2d7194bb8fdbc56d8a7c9b6c0e392041_3_schematic.svg.bak’
At line 4
ReferenceFile
‘OPTOCOUPLER X4 SCH.svg’
‘OPTOCOUPLER 4CH_2d7194bb8fdbc56d8a7c9b6c0e392041_3_schematic.svg’
Corrected
Modified 4: File
‘svg.pcb.OPTOCOUPLER 4CH_2d7194bb8fdbc56d8a7c9b6c0e392041_3_pcb.svg.bak’
At line 4
ReferenceFile
‘OPTOCOUPLER X4 PCB.svg’
‘OPTOCOUPLER 4CH_2d7194bb8fdbc56d8a7c9b6c0e392041_3_pcb.svg’
Corrected
Warning 6: File
At line 2
ReferenceFile name
‘2-channel-relay-module_1.fzp’
Doesn’t match fzp filename
‘OPTOCOUPLER 4CH_53b951f7e12564af33ab05b3ac698a0f_10.fzp’
Warning 32: File
At line 2
Scale is not the desirable 1/1000 ratio from width/height to
viewBox width/height.
Warning 23: File
At line 22
Key -inkscape-font-specification
value ‘Droid Sans, Normal’ is invalid and has been deleted
Warning 32: File
At line 2
Warning 23: File
At line 142
value ‘OCRA, Normal’ is invalid and has been deleted
Warning 32: File
At line 2
Warning 20: File
At line 30
copper1 layer should be at the top, not under group copper0
Error 69: File
At line 21
Error 77: File
At line 18
terminalId connector146terminal can’t be a g as it won’t work.
Error 77: File
At line 19
terminalId connector147terminal can’t be a g as it won’t work.
Error 77: File
At line 20
terminalId connector148terminal can’t be a g as it won’t work.
Error 77: File
At line 21
terminalId connector149terminal can’t be a g as it won’t work.
Error 77: File
At line 22
terminalId connector129terminal can’t be a g as it won’t work.
Error 77: File
At line 23
terminalId connector130terminal can’t be a g as it won’t work.
Error 77: File
At line 24
terminalId connector131terminal can’t be a g as it won’t work.
Error 77: File
At line 25
terminalId connector132terminal can’t be a g as it won’t work.
Error 77: File
At line 26
terminalId connector133terminal can’t be a g as it won’t work.
Error 77: File
At line 27
terminalId connector144terminal can’t be a g as it won’t work.
Error 77: File
At line 28
terminalId connector142terminal can’t be a g as it won’t work.
Error 77: File
At line 29
terminalId connector143terminal can’t be a g as it won’t work.
Error 77: File
At line 30
terminalId connector141terminal can’t be a g as it won’t work.
Error 77: File
At line 31
terminalId connector140terminal can’t be a g as it won’t work.
Error 77: File
At line 32
terminalId connector136terminal can’t be a g as it won’t work.
Error 77: File
At line 33
terminalId connector151terminal can’t be a g as it won’t work.
Error 77: File
At line 34
terminalId connector138terminal can’t be a g as it won’t work.
Error 77: File
At line 35
terminalId connector137terminal can’t be a g as it won’t work.
Error 77: File
At line 36
terminalId connector150terminal can’t be a g as it won’t work.
Error 77: File
At line 37
terminalId connector134terminal can’t be a g as it won’t work.
Error 77: File
At line 38
terminalId connector139terminal can’t be a g as it won’t work.
The reason pcb isn’t working correctly is that the .fzp file isn’t correct (and parts editor AFAIK won’t usually modify the fzp file, it needs to be copied from a part with the correct number of connectors to work.)
here we see connector5 works but connector6 doesn’t. The reason is this in the fzp file for the part, connector5 is properly defined with a pcb view defined so the pins work.
    <connector id="connector5" name="G" type="male">
      <description>GND</description>
      <views>
        <breadboardView>
          <p layer="breadboard" svgId="connector5pin"/>
        </breadboardView>
        <schematicView>
          <p layer="schematic" svgId="connector5pin" terminalId="connector5terminal"/>
        </schematicView>
        <pcbView>
          <p layer="copper0" svgId="connector5pin"/>
          <p layer="copper1" svgId="connector5pin"/>
        </pcbView>
      </views>
    </connector>
connector6 is has no pcb connection information and thus doesn’t work.
      <description>V+ IN TO LED CH4</description>
      <views>
        <breadboardView>
          <p layer="breadboard" svgId="connector6pin"/>
        </breadboardView>
        <schematicView>
          <p layer="schematic" svgId="connector6pin" terminalId="connector6terminal"/>
        </schematicView>
        <pcbView/>
      </views>
    </connector>
note pcb view in this entry is an empty group so the pins don’t work. The following tutorials on part making may help (I as you will see, typically don’t use parts editor as it wasn’t completed when development stopped in 2016 and hasn’t yet been finished.) I tend to directly edit the underlying files which I find much easier than fighting parts editor. Both of these tutorials apply to current versions of Fritizng many of the others are for older versions.
Hope this helps, if not feel free to post again.
Thank you for your advice.
I spent a lot of time reading through everything I could find, and I think I finally fixed it good enough for my purposes. I ended up fixing the .svg files, and editing the .fzp file in Xed text editor. That seems to have fixed it.
If someone wants to use or improve the fixed (good enough for me) version, here it is…
OPTOCOUPLER 4CH.fzpz (57.0 KB)
Looks good, the only thing I see is that the holes in pcb are 0.043in, for a 0.1in header (assuming you don’t want larger holes for thicker wires which you may!) should be 0.038in. In Inkscape (which looks like what you are using) the hole size is set by
hole_size = pad_diameter - (2 x stroke-width)
