hello everyone,
I’m looking for rocker dpdt switch (6 pins) in fritzing but had no luck finding it. I’m going to solder this switch onto my pcb. can someone help me with the part or create a new one for me if it isnt available? i’m attaching pictures for reference.
                vanepp
                    November 16, 2023,  4:16pm
                  2
              This post is likely as close as there is
              Hello Peter, do you have the exact same one as the image above? I can’t take the one with a different look. Thanks
                vanepp
                    November 16, 2023,  5:38pm
                  4
              This is as close (and it is SPST not DPDT) as exists at the moment.
    Hi Fritzers,
I am wondering if someone could make a illuminated rocker switch? As far as I know, it’s a SPST switch with an added ground terminal to make it light up when the switch is on. They are generally used for 12v automotive applications from what I gather.
I got fritzing to try and simplify/straighten out the wiring in a project instead of doing it on paper and found myself having myself dealing with added complexity of not having the right part… sigh… I’m sure eventually I’ll make it …
in general since switches come in infinite forms it isn’t worthwhile making custom parts for switches in most cases.
              Hi, what about this ya? You have any idea? Need help on rocker switch up down
