I’m looking for rocker dpdt switch (6 pins) in fritzing but had no luck finding it. I’m going to solder this switch onto my pcb. can someone help me with the part or create a new one for me if it isnt available? i’m attaching pictures for reference.
This is similar in nature to the other switch. There isn’t enough information here to do anything with it may be dpdt or spdt it is impossible to tell from the picture and it doesn’t appear to be pcb mountable. The illuminated switch is about as close as you are likely to come. In general images of parts are pretty much useless. A data sheet with mechanical and connection information is needed.
