LRS-50-5 Can this part be created please
Name of the part❗
LRS-50-5. Meanwell 120V to 5V, 3A DC power supply.
This parts in similar but not quite it. MW-IRM_05-05
Top view❗
Datasheet❗
Unsure, but the pdf is listed above. Part number is LRS-50-5.
5V 3A AC-DC Power Supply
It isn’t worth making new parts for power supplies. A search in the forum search bar for power supply will turn up the available parts (the S360 may do you or one of the generics.)
Fair enough. The link of the other MW supply is good but can the name be changed to display “LRS-50-5” in schematic view? I will be passing my schematic down to a separate team of technicians that were not involved in the design. The name being different may spark confusion when replacing parts/troubleshooting in the future. Is this an easy and doable solution? Any help is more than greatly appreciated
Disregard. I found a simple generic power supply part file I will use. I appreciate you swift response, Peter.
Same response as for the FLIR part the same thing can be done here. These two tutorials may give you enough information to do what you want.
Old_grey’s videos may be your easiest route.
