Hi!
I am looking for fritzing parts for C3/S3 mini. I am unable to find it anywhere.
https://www.wemos.cc/en/latest/c3/c3_mini.html
https://www.wemos.cc/en/latest/s3/s3_mini.html
Thanks for your help!
Regards,
Jaromir
Hi!
Regards,
Jaromir
These two parts should do what you want.
lolin-S3-mini.fzpz (19.0 KB)
lolin-C3-mini.fzpz (18.4 KB)
as usual if you want the mounting holes (which are not drilled by default) you need to drag a hole from the pcb section of core parts in to your sketch, place it over the hole in silkscreen and set the size appropriately. As well (because I don’t have either of these and thus the parts are from the data sheet) it would be a good bet to print the pcb footprint out at 1:1 scale and compare the footprint to a real part before ordering boards.
@vanepp Thank you for really quick response !
Btw. what do I need to start creating parts by myself ? I am currently testing the software, but I have 0.9.6 version (x64, Linux) with the option to create parts disabled.
I assume that I need to install at least 1.* do have it enabled ?
Is there a process to include newly created parts into std library ?
Once again thank you! Merry Christmas and Happy New Year !
Regards,
Jaromir
AFAIK parts editor (and parts creation in general) works on all Fritizing versions. That said parts creation is complex but these two tutorials apply to current Fritzing versions:
