Does anyone know if the LTC3260 component is available in Fritzing, or does anyone have an idea on how to create this component?
There doesn’t appear to be a part. You can create one by using the generic IC and changing the pin labels
Thank you, Peter! Do you perhaps also know how to create the block diagram of the chip if you are simulating the circuit? Or is it perhaps better to just build the block diagram?
ltc3260.pdf (analog.com) page 8
For the block diagram you would need to create a custom part (these two tutorials detail how to do that although it is quite difficult)
simulation requires a spice model in the part (and currently only does DC simulation) which is yet more complex.
