i am currently make my capstone project that use atmega8535 and im can’t find the part in fritzing. can anyone help? I am relatively new to Fritzing and would appreciate any tips or tutorials that could help me in this process. Thank you
There doesn’t appear to be a part available. Are you looking for just the IC or a module that uses the IC? If you are looking for just the IC the generic IC in core parts will let you make one by setting the pins to 40
and then setting the pin names via the Edit pin labels option in Inspector
here you can replace the text on the pins in the editor and then save it to make a new part. For more complete part making information (although it is fairly complex) these two tutorials apply to current Fritzing versions
If you are looking for a module we would need a web site that describes the module with dimensions and connector information.
