Hey! I am looking for Electronic Speed Controller for Brushless Motor - LittleBee 20A 2-4S LIPO
Something like this:
Thanks for help!
Thanks for help!
This should do what you want.
Replace part with one that has the pwm connections added.
Littlebee-20A-ESC.fzpz (3.7 KB)
Thanks! it is a big help for me!
Actually It is missing two connections for PWM signal and GND. If you provide me an instructions how to edit it, it would be helful
Editing it isn’t that easy, although if you want to learn to make parts these tutorials should help.
Where are the connections (the documentation is as usual non existent?) Never mind, I see where the connections are in another photo. I’ll add them and replace the part.
I wanted to check if there’s any update regarding the part. Were you able to add the final wires?
Also, if anyone has any information or an Electronic Speed Controller (ESC) available, I’m interested.
Thank you in advance for your help and response!
The part was updated at the time with the requested connections.
This is an ESC. You can find more via a google search for “fritzing part ESC” (or with the model number of the exact ESC you want.)
After several searches, it seems impossible to find an ESC with three outputs (VCC, PWM, and GND). All the models I’ve found only have two small outputs. This specific type of ESC is not available on Fritzing.
I’m attaching an image of the component for reference. If anyone has suggestions or knows of a matching model, I’d greatly appreciate it.
Thank you in advance for your help!
Not enough information to do anything with. I would need a data sheet with physical dimensions and connection information to do anything much. Pictures are basically worthless.
Here’s a link to one of the sellers of this ESC. You can find various details on this page: 40A Brushless ESC Speed ​​Controller - Drone Avions Pièces Composants – RCDrone
Feel free to check it out if it might be helpful!
