Si4432
(https://www.silabs.com/documents/public/data-sheets/Si4430-31-32.pdf)
Can somebody help me with this part?
Si4432
That depends (since there isn’t enough information here to do anything with.) Do you want just the chip (which is the data sheet you posted, or the module in the picture. If it is the module you want a google search of the form “fritzing part Si4432 module” turns up one here
although it doen’t appear to be the same as the picture. If you want that particular module you would need to provide a web site which contains the physical dimensions of the board and the connector information,.
i think this link will help you. it contains info about the physical dimensions but i could not find anything about the connector here. maybe i misunderstood you and you will be able to find needed information
also, i saw this link but i am having trouble understanding how to edit existing parts to fit my needs
Making parts in general is difficult. @vanepp will show you two tutorials
That is generally difficult. Here are a couple of tutorials that will tell you how if you want to try. For a small number of parts you are easier to ask with sufficient information. I will look over the supplied sites and likely make a part.
I also happen to be creating (or rather!) fixing. It’ll be very important when modifying things from the web. I’ll post the log soon once I’m done. Inkscape keeps fighting with me whenever I try to ungroup. (Which brings up another thing – don’t group too many things either…)
thanks a lot for helping guys! i’ll check out the tutorials!
OK here are your two parts. One is through hole (THT) sized for use with 1.27mm headers, the other is SMD designed to be soldered to the pcb.
E27-433M20S-tht.fzpz (12.8 KB)
E27-433M20S-smd.fzpz (12.8 KB)
thank you very much! that’s exactly what i needed!
