I need some parts
i need an a [orange pi zero 3,orange pi zero 3 2 usb board,cc1101,2pin button,cardputer with sd snifer(NOT CARDPUTER ADVANCE)and other(any part)] i will send photos of that parts in a comments
Orange pi zero 3(withour antena)
and 2 usb board
cc1101
more photos
2 pin button
m5 cardputer
more photos
more photos x2
Photos are essentially useless. What is required (which the template that you apparently ignored is asking for) is a web site that provide the physical dimensions of the part along with a description of all connectors with names and physical descriptions. The images provided so far are not useful. The place you should start is a google search of the form “fritzing part part description” (where part description describes that part you want.) That will pull up available parts (at least some of them may already exist.) For large numbers of parts you likely need to learn to make them for yourself. Reading the forum posts will find you pointers to part making tutorials (which is admittedly not at all easy.)
orange pi zero is an 50x 55y mm
usb board is an 40x 46-47ymm
cardputer with sd snifer is an 83x 84-86y mm
button is an 6x 6y mm
cc1101 33-34x 15y
x = X
y = Y
i cant found more info but i have that part in real life so i can send more photos an info
i will found sizes of that parts
You may want to look at this post (which was found by a google search for “fritzing part Orange pi zero 3” and is instructive on how to find parts and what is needed to make a part.) The rest of what you want is likely similar some of them may already exist and require sufficient information which is not present to do anything with.
A google search for the other parts you want would be a good start there are cc1101 parts I believe the cardputer likely doesn’t exist as a Fritzing part although sd sniffers do.
I didn’t find these parts, so they will need to be created
@DEXTORON Please send the websites of each individual part.
ok i will try to find it
orange pi zero 3:Orange Pi - Orangepi
cardputer(withour cardsniffer):M5Stack Cardputer with M5StampS3 v1.1 | m5stack-store
sorry i cant found more
but i need cc1101 usb board for orange pi zero 3
orange pi zero 3
and cardputer with card sniffer
You need to learn to read the replies. The Orange pi part exists and is in the post listed above which was found with the listed google search (which you should have and could have done for yourself.) A google search of the form “fritzing part cc1101” finds a module here:
The micro sd sniffer part is available in this post. (the Cardputer doesn’t appear to exist as a Fritzing part and can’t be made with the supplied documentation as it has no connections Fritzing could use.
that not that cc1101 that have 10pins i need an 8pin ver
and i need ohter modules
Then you need to provide a web site of the exact board you need as has been requested multiple times. Without sufficient information we can’t help you.
