Help With Part ESP32 S3 DEV KIT N8R8
ESP32-S3-DEV-KIT-N8R8
Previous work, similar parts
Sorry, but i’m a new User and can’t include more then one embedded pictures in a Topic. So the
Picture with the sizes i’cant Upload. In the link down you will find these picture.
Please add a link to PDF of the manufacturers datasheet:
Hi, there can anybody create this part for me please?
A google search of the form “fritzing part ESP32-S3-DEV-KIT-N8R8” turns up this post which may do you.
Thank you very much for this surprisingly quick answer, this is not exactly the same ESP32, e.g. mine only has a USB C port, but it is compatible with mine. The rest I think I should be able to do with the part editor and Inkscape.
I will post the part here when it is finished for others who are looking for exactly this ESP32.
Another question: Is there a library with single svg files of parts which are needed to assemble a new part. For example only the USB C connector, an IC or even a single pin.
Many thanks in advance for any answers. Please also write to me if I should open a new topic for this new question.
*** Translated with DeepL Translate: The world's most accurate translator (free version) ***
If you are looking for the 2 USB C version there is one here (found with the same google search.) There are a bunch of ESP parts floating around (mostly in the forum but not all of them) so you need to search using google to make sure you are not reinventing the wheel before making parts.
Asking here is fine. The answer is more difficult. I have a library of breadboard only parts (without connectors) to add to breadboard svgs @RAPTOR7762 has posted it on github somewhere I think and collections of various parts that I use when I need ones with the appropriate connectors (which haven’t been posted so far) but there isn’t a public repository I don’t think. If you want to start making parts these two tutorials (which apply to current Fritzing versions) should help. You may have already seen them, they get posted here a lot.
