Help me creating this TTL RS485 module
i’ve been searching about this part but there is none, i want to make it by myself but i dont have an app for editing
In general there isn’t an “app for editing”, the usual case is start from an existing part and use parts editor (which I don’t!) and an svg editor to make parts. Instructions that apply to current versions of Fritzing are available here:
That said, making parts is difficult and if you only need a small number of parts probably not worth doing. In such a case you should fill in the template in this category with a web site that provides the dimensions and connector information for the part you want (or first do a google search of the form “fritzing part part_description” where part_description is the model number or description of the part. That will find any existing parts (and a search for “fritzing part ttl rs485 module” turns up a variety of hits) and is the first step in making a part (don’t reinvent the wheel!)
We can help you make one if needed, as your image has all information needed for a part. I won’t be making this as I need to fix some Adafruit Parts
yes please, but let me make it by myself, i want to try what vanepp talk about
OK, then post the .fzpz file once you’re done, then we will check it for you
First do the google search as an existing part may do you and would be easier. I didn’t look closely at what is out there but they may be what you want and not making parts is the best option.
i found this, but it doesnt have the same red color but the pins are ok
RS485_XY-017.fzpz (537.8 KB)
@Shinkwe111 This part has a fair number of issues. Pins are not OK. The hole sizes are way too small. I’ll create one from scratch
@Shinkwe111 This should be the part you want
TTL RS484 Red Board.fzpz (13.9 KB)
thank you very much for the help
No worries @Shinkwe111
