Hey all,
I just started to use Fritzing to explain how to connect parts. Most of my projects work with the Grove Base Shield and Grove Sensors. I have managed to import and use the file for the Base Shield from this forum, so so far so good.
However, I wanted to connect a Grove - Temperature&Humidity Sensor (DHT11) https://wiki.seeedstudio.com/Grove-TemperatureAndHumidity_Sensor/#schematic-online-viewer to this, but I can’t find it. When searching for parts I read that you need eagle files to create a new part. As far as I can see Seeed Studio provides this. Only, where do you go from here? I can’t open the Eagle files with the programs that are on my laptop (MacBook pro Big Sur). Can someone give me some guidance as to how to make this Grove sensor for Fritzing?
Thank You!
