I tried to stick to this tutorial to create a part for a generic Halogen lamp with G4 socket.
Now, testing that part, I can’t connect a wire to the legs in the breadboard view. But it was no problem at all to select the legs as connectors in the new part editor.
The file is attached and any help is welcome.
Best regards
Samuel
Halogen Lamp G4.fzpz (8.8 KB)
vanepp
September 6, 2022, 2:43pm
2
You started from a bendable leg part which won’t work here (and which parts editor can’t correct.) You need to edit the .fzp file and change this
<views>
<breadboardView>
<p terminalId="connector0terminal" legId="connector0leg" layer="breadboard" svgId="connector0pin"/>
</breadboardView>
to
<views>
<breadboardView>
<p terminalId="connector0terminal" layer="breadboard" svgId="connector0pin"/>
</breadboardView>
to match the svg. These 2 tutorials may be a better bet:
NEW FASTER PART MAKING VIDEOS AT THE BOTTOM-Fritzing Parts Fast
ADVANCED FRITZING USER TIPS & TRICKS VIDEOS AT THE BOTTOM-Fritzing Adv Tips & Tricks
A series of part creation videos - I’m not an expert, but there was nothing else around at the time.
Use 1080p HD fullscreen to see details clearly - use gear symbol bottom right -.
Recorded slowly for older people, so select a higher speed if it’s too slow.
P.S. - Sorry about the voice/sound
Fritzing Part Creation - Chapter1 - New Part …
Someone in this forum post
requested help to fix up a part. So while doing that I decided to record what I needed to do in order to fix the part to provide a tutorial to create new / fix broken parts. If you start from the Tarjeta S4A EDU.fzpz file posted in the above thread, you should be able to recreate my improved part posted in the same thread. I started by loading the original part in to Fritzing, that indicates breadboard is (at first look anyway) pretty good, but schematic and pcb are…
Thanks
that worked like a charm!
