Hi there…
I can’t edit any labels on the silk screen. Went through all the menu & subs, didn’t find anything.
Anyone could help?
Thx so far!
Freddie
Hi there…
Anyone could help?
Thx so far!
Freddie
You can’ edit the silkscreen of a part from Fritzing. You need to modify the pcb svg and create a new part. This is why there normally isn’t text in parts. You can add new text in a sketch, but you can’t remove text in a part without modifying the part. Part making tutorials that apply to current Fritzing versions are here (although it is quite complex!)
Hi Peter,
it looks, like I misspoke…
It’s not the labels, it’s the txt-fields I meant.
Freddie
In pcb all silkscreen is black (it used to be white many versions ago) and the color isn’t changeable. I believe most board houses will let you pick a single color for silkscreen on the order form, I don’t know of any that do multiple but there may be (but Fritzing likely won’t support it!)
don’t talk of color…
I want to edit the txt-fields itself!
Like I said, I did the PCB a while ago, I did all the custumized TXT-fields but I forgot the way to get there…
Freddie
Hi Peter,
YYYeeesss!
Thank you very much!
This is what I was looking for! I unchecked the Inspector and was not able to locate it anymore…
Sometimes you can’t see the forest for the trees!
Freddie
