I just got this software and I’m trying to create a simple customized part that is based on an existing board. I added the part to “My Parts” bin but when I right click on it, the “Edit par (new parts editor)” option is greyed out. In fact, this is greyed out for every part. The parts_editor_help.phtml says that I should be able to create new parts from old parts so I am very confused. What am I doing wrong?
The parts bin is read only so parts editor can’t edit the part there. You need to drag the part in to the sketch then select the part in the sketch (which is writable) and parts editor should be active. I will note that modifying parts is difficult and if you need only a small number of parts, probably not worth learning. The first thing to do is a google search of the form “fritzing part part_name” (where part name is the part you want) which should find any available parts. Note not all parts on the net work correctly so check that whatever you find works correctly. If you want to make parts these two tutorials apply to current Fritzing versions
Old_Grey’s tutorial covers parts editor, I rarely use it and thus didn’t cover it. Good luck (unfortunately you will probably need it !)
I don’t see a way to edit the part once I’ve placed it in the sketch either. I found videos on how to edit the part, but they reference unselectable options like “Edit Part” or “View > Parts Editor” or right clicking the part in the sketch and selecting “Edit Part” there. The latter of which isn’t even an option in the right click context menu.
For me on Fritzing 1.0.5 on Windows, works fine. Here I drag the generic IC from core parts in to the sketch then right click on the part which opens a menu, and select parts editor.
I appreciate your reply but I’ve already tried re-installing it using the MSI installer that I paid to access today. It just doesn’t seem to work for some reason.
Ah! The perf board is a parts factory created part and you can’t edit it with parts editor I don’t think (as it likely is created on the fly and doesn’t exist to edit.) Does the generic IC that I used work for you? If not there is a deeper problem somewhere. If you don’t have any imported parts in your mine parts bin clearing the user directories may help (the user directories don’t get cleared when Fritzing is installed to keep your imported parts, back 5 or so years ago this was a more common problem, it hasn’t been an issue in the last few years,) Here are instructions on how to clear the user directories
