BIGTREETECH EBB42 CAN
Greetings, i need search the EBB42 module, i can’t find it.Also how to create pieces in Fritzing. thank you
There doesn’t appear to be a part for this (a google search of the form “frtizing part EBB42” will usually turn up any parts that are out there.) I’ll make one in a while (I am making another part for someone at the moment.) Making parts is not particularly easy, but is documented in these two tutorial sets (which apply to current Fritzing versions which not all tutorials out there do.)
When you run in to problems feel free to ask here and some of us will help you out. It is easiest if you upload the .fzpz file of the part you are having trouble with (or the .fzz file if it is a sketch.) Upload is the 7th icon from the left in the reply menu.
This part should do what you want. PCB view is suppressed as not being useful.
EBB42.fzpz (28.9 KB)
Thank you very much for helping me, the module will be very useful.
