Hi everyone, I am working with the white opaqued 8mm (THT) RGB LED WS2812D-F5 and could not find it in Fritzing’s Led library. Instead, I just found the 5mm version of it with bent pins and the white clear body. Could you guys tell me where can I find its library? I added its datasheet below, and the link where I bought it here.
8mm [THT] RGB LED WS2812D-F5
Previous work, similar parts
