I am a student building and testing a 1/5-scale autonomous vehicle. I need to create a schematic for the vehicle I built. Could you create a Fritzing file for the following components?
25Amp 7V-58V High Voltage DC Motor Driver [MD25HV]
This is as close as you will likely come. It is not worth making parts for specific batteries a generic version is the answer.
There are a variety of Cytron motor drivers available as Fritizng parts although it doesn’t appear this particular one exists. A google search of the form “fritzing part cytron motor driver” should find the various ones that exist. Same thing for the SZH-PWSDF-036 that particular one doesn’t exist but there are similar ones around. A google search should find those as well. You can also make parts for your self (although that is no where near easy) these two tutorials on part making apply to current Fritzing versions:
