Howdy, would some kind soul please lend a hand and make a fzpz for the Lilygo T-Display-S3.
Let me know if there is anything else I would need to provide.
Thanks kindly,
Thanks kindly,
Will this existing part do what you want (I am too lazy to check)?
note the first part is the wrong one, the T display is down the list of posts.
This should do what you want.
edit: Corrected an error, there is only one 5V pin not 2, there are 3 3V pins not 2.
lilygo_t-display-S3.fzpz (8.6 KB)
Lovely, thank you Peter.
I just corrected the part. There is an error in the power pins, I had set 2 pins to 5V when there should only be one. So you need to download the part again to get the corrected version. A delete minus will delete the part but leave the traces if you have already used it in a sketch.
