ISO: Songle SRA-12VDC-CL PCB relay
SRA-12VDC-CL
Previous work, similar parts
ONLY similar with different dimensions: OMRON1
12V-20A-DC-Power-Relay-SRA-12VDC-CL-5Pin-PCB-Type-In-stock-Black-Automobile-relay
https://www.rlocman.ru/i/File/2018/02/21/SRA--T74-.pdf
UNK
This part should do what you want. Note it would be worthwhile to print the pcb footprint out at 1:1 scale (the default) and compare it to a real part.
Songle-SRA-12VDC-CL.fzpz (4.6 KB)
Awesome! I haven’t tested yet, but appears correct dimensions. Did I miss that in searching, or did you just pull that out of your… head? :laughing:
Speaking-of, could you point me to the latest and greatest parts-making info? I tried years ago, but it didn’t take. I’ll give it another shot, as I’m needing more parts. Thanks! :+1:
While there is a songle relay part it isn’t this one (and has a different form factor) , so I made one. In general a google search of the form “fritzing part SRA-12VDC-CL” will find existing parts. There hasn’t been much new documentation on parts making, but here are the standard two tutorials:
Fritzing PART CREATION Video Tutorial Series
They have both been around for quite a while so you may have already seen them (and things have not gotten any easier in the interrum!)
Thanks for both the part and the pointing! :+1: Off I go!
