hajar
December 13, 2019, 8:21am
1
I searching how to add the same module for lora in my project as the link below
https://osoyoo.com/wp-content/uploads/2018/07/lora-transmissor-777.png
and thank you so much for advanced
vanepp
December 13, 2019, 6:07pm
2
It looks like they have but have not published a Fritzing part for this module. So you should ask them for the Fritzing part, or try one of the other ones that show up in a search for
fritzing part osoyoo lora module
which turns up several parts (although not for this particular unit) or we could make a new part if there is sufficient information available (which it looks like there is.) First try the osoyoo folks (because the other 2 modules found in the search are not suitable) and if they don’t respond ask here again and I’ll consider making one.
It is your lucky day. I was making a new tutorial and needed an example part, so I used this and thus made a part for this:
ossoyoo-lora-module.fzpz (6.4 KB)
mrnams
September 23, 2021, 5:34pm
3
Can you please share SX1278 Ra-02 Fritzing part (.fzpz)?
vanepp
September 23, 2021, 6:48pm
4
Will the part at
PK6LNÃû½7:4part.Semtech_73633d6a2582aec858e2fc58b4227ae6_20.fzpí[]rÛ8~Ï)°|'ðWÿ²¬)G²'ZG±ËtÝ'D"ÆüY·vkæ$s=ÃeN2
åÌÈ»MWmK"úcÝM ÷~üè°ÆÑÁ©{DNìÒhz°÷ñâXmïýØÑcw}ÜÅ&!'Ùª5k5·FÛÂÄi7ÚÄòF{R·¬&ÍKËPÇ(¿?åzCkif´4ÃÒf
dñÕää@ÎjѾ¼´<£CL³æYnÓcøët¼v^¯»6it4ï&Qú/Pϸ³þÇ==¿VNy@úçX5L¤¢÷ñ9FãìYì¿V«ÝÓ3
ðý55A9éãýGȲe0T¶Bï}ó$íêú|>×ÒÌ8zÂ`.§ú24U§1Ã*g8JBõõ%1§)|Ë pÂÕ²Å>-ä·í¦0NI62¿] `P4X(ý%¾Ø$`ÆQ4')ý%¶¢×Qq¥_ ³X>À1õw&%ÔáH½ðitEØùÕMöȽkJæÙ³S'>Á¸Ä®ÑOaRѧ/Ý·Ûé5Ïô¤vÌθÔ[3æ¥×Òë©"'ËgCòSèVôLiôu½ #ØÄ¹÷Áºx¸ÛQo6ý[/u|bNûЮv5¨ëJf#ÔopõgrFèz:/ÀåÄ x¹Õ-¾ôÁ°Ç¹Ðê6wíñ©=R_$pâ(J-¹T-ÑsIê0pÈý(Fk·hA8d µ~9`NX,{¨;n8a!p0ºbÙª 0ÌÝ®.½~£mô¡uå·<ÿº7¨¹ãëJ$~;¥¤`5ç§ÒoÓ¾°ÓáèÔ*àÔlTT³q¿eÍÆ®i}öR5¥0;Ù§ÌÖ«@lý~ËÖwMëÖºK!µ^V´Ö¢µYRÍfA¼4wÛk/'Z¥0kN
D.H;ÏÁ[ë.Ór0k£ÓJÄjA°ì<R·Ö]
§å)pZ/à´UN[÷ÛµµkN·Ö]
§R8ýéðÒöJݱC"xGìÐöýFmïÐuBh»B?\Ú©Bvî7kg×n»J;£¦ñ Øõ¢×(Xv;_ôn¯½E¯Q
«5ö©V³
¡j¶5wÎìöÚËaÖ,Ùó#û¨( V%¨µ
kíÚíµCõ©ø;ømïÔ«îÒmuChY[£ÐJõÍÚº¹óÂþ´Cl9µ}µb+RàÎóïÖºKá´äÁjk%ªúfAiÝÜy]ÿÚË Öÿ¦´¿v'y]çãïÿex:¸øûÙzw1~Î>¾}? EÕõϵ®/YG]3týèq#?É1¯i1êçúùÑ@õyÔ
=å:\s¹"4v©ÊäEH8ÎÝìû|å
ÞÝ
<º.åR¾HîBFwÒ&MÞ ¢ ¹O9QÓ^ù]0¢ÎNöÑ?¥V]Óè+ÅØ] Ùq ô©ÙÁîÞØF¶O
)²öö³ÞÞn[³ Ï[æN}ÞÆRDÌÖbÜìçO¬tMi¤ò8éÉ×ýåý$æ<ï4ÄãwT$[Ô/\±s¥ÒÈuA¹°ÇêþOPvgý G01M÷Çz@AÊhKqhº=O¢Ië%z(&ÁOÁÚ¾*Øé0áýG}ZI'Ëå
%7ÝKiüW(MC=ê`c)ò(Dë &8NãØ' ä ÕÝ\=
NYQ'U3¦TA¥j'"yÁèêçåa©L³ú1à«Ç©¦q2VëµÚXMTÓ¬fGñ÷lü?ÆgÃÛwL÷éÑÅsÂP:KHôh80µ¶ZÓZ^¢Ð«§Ç7ðiÒ]fæ§sÌȰH$þÍÓC:õdSñÀ×3¯|µnüëu»ñmX>Ku$Öa4pÑZA/C¼@×-Äú$]¼ª@bÙcÓPVcü®qrvØE¯Í¶û6|z,bá¢Û'ºa\=[×÷å wö_)¯@þþËoÙfç÷_u·X%Ëå·X%gÿ!áHlq¢8§j`¶gð½'S]0$»ß0Eù®q5 ¾¶È'°±0ÂÏè:8
°ÍaN"¹±<?F\gÅ3Ìx5°¿A(%QJ9½¦V4A<¿
¨f½YR¢ÄÜY¯È>Ýõj@<c1¤À0ÄQ" °Ûä$E³Dز ~¤Õ
ħÞ<oÐOòs,/åç*WàÈE§§'k9¢øaà¾Eç¶=Bî"Â!uÃÑTÝáæULî)F8@.ä*ø
Ùâ,öªòA
9¸èðxóBýÑã3å¾ÌZóÁÜFÂc%ع"</U³â¬ÏDBò
äÇâÞd3®§Ø>%ø7IªjE@%²E9ÂËz]M~úp^2Eë?ýzÑÓ³ÿðì¿øPK6LäGcõ:¯Hsvg.breadboard.Semtech_5a8b71f03f1fef018919bedee470cbb1_1_breadboard.svgí}YIræûþõ²²¢ý>iÔyÐ]ý"Øì.bªaÍ¿_û>3"³LÒ*3Ìâðp7·ÛþðÛ»oþã§ûöÙýÛ·¿þÓ7ßüõ¯]þ_ÞüøMpÎ}#ÏnnÞ½~õ×ùå?¾}ænÜMÊKÌ)ÆÔßZoÏn~üåÍÏrðÙÍý«×?Þ¿ýö¯?ýôìæõ÷ß>û×»¿½zóoþÙÍ__ÿö^ùþîíÝíÏw?½2ÿìÿÇüûÃ÷¯~{y£óûW?¼zóêç¯þ×ëW7ÿüïn¿ý×_þûWwßÿû/wo¾_ä.ÿðÍ#L;Û78ýýöõÛß=þáQÃüñf<Ñô)6Ìg»{Ûã-N1ÿÏÿe2ÐÞ¾¹ûù·~yóÓ·ÏøçÃÝÛWÿó¶Õ¥§òM(néÞûþ7o~yËcÝýã{ç±s}øãß=ðÑOBx2ÒI'#Ep6 ß¼zùöÑk>þú),¥Õlóæîåש¿¿}û¬õ%ôVd~ɲ
>,5È¿g7¿½ýÛ¬^?<üÓÍ?èîÙ7g<ñ7?8®§<ùIEú»¿{ðè~üðÇËzñö*_½ýë«W?_¿·Àãj
þ&ô¾´ºÿØ·ó͵ü."$±2u[Zu®k;,-'_¹´}(KϵT]Û¹.Þ»òé6oçÔå}ÑWÀwU׺Z²lÛ=-®åP檾àl¢I|ʪö/ιªÏGüWµìõ®rZ[ϽÎU}ÁÙDøUíóº«q®êó¿âU]ÊcíUVµ¨X©¹ª/#8è"B°ª¨[Á§4Wõù_óªvK)´ ²¸«5¶¹ª/"8è"B²ªÓâ³,빪ÏGüWuNKï=vYÕ~I®¹Ãí|sUb¢IüôUÝEÛj¡å¹¨ÏGüuêKÌ5ÆPòRKqq.êÎ&ºÄ',jù\ísQø5/ê¸ä\\¹ ¹/½¤:µêËÎ&ºÄO_ÔMtØó4]ø/êÖÖåÝßDÐ{Jõeg]DHâêXSJõ_óª6¦}|EËOñû2³."$ñ¹;µK f³¹¨O@üõP¯nBKhµ窾àl¢I|®R=WõY_óª6K¨¬êºôÊÜ«/#8è"Bkÿ«ú,įxU¯^Ëã{ìa.ëÎ&ºÄg;«çº>ñ«^×c$ëº/¡Ä0;.#8è"BZ6×õY_óºÁ7!¥¥Çç²¾àl¢I|vø\Ög!~ÍËz¤ïÜìâ|ÑeMt!ÏÎÚëú,įz]Çzô²®Ë"ïÖM·õeg]DHâÓr¬ùÚ纾ñk^×#.á&¾ø©^_Fp6ÑE$>;e®ë³¿èºþð¿ræBËá&:·ÔôJ
¿;çÂÿôD$|¼vÃKÈ»¥«_¹#÷%çGÌ·èÓÞ¥üþÊýáf9£ÏµúyT×ȪýöúáÏ¿½|óaa£?üúËÃß~üåçyo~ùó«ÛQ¿íÙͯ¿¼þùíoß>Kkù&%6TMXzéï}e)±Ü$áø¢x?þÏx@òÇÛö'¶¿ïQhíO¯îÞþÛÿûÙ^½yTQGn¶#6ÿì1~zýöÕ×þéÆË©0-¿}vó¯~xõÃî=-~¹wù®½?Y.¤ßçpÁ§ÅûVûÍm+KNµµ)ºüg]~½{{s#óídZ¼÷Kèá>,®¤ß9ÌëîoÀX]}w+Ç}iw2]ýNþûÃsÈIÆk>à,>×*ÌðR¿]RY.¶¤ÚSZ¡)ûãâZuìÞ¯p\ª9q!Rxâê
%Tò}NQîR¨år¯©-±àp¤»/.â©åØÃ
Îí\xacóÝO·N¦ûÁ½,.ç;/,¡òiâ
îvq¹ç
$ßr@ÄîÛÉ×Z£ Å,#(KsµlPDìY÷bè+4¤ä÷ädßÂP÷îÃ
This file has been truncated. show original
do or are you looking for a breakout board of some kind (the breakout board would appear to be the ossoyoo-lora-module.fzpz file two posts above?)
mrnams
September 24, 2021, 2:19am
5
vanepp
September 24, 2021, 7:43pm
6
This may do what you want. The part was created from a jpg image on a web site and none of the web sites have dimensions of the board so the size may not be correct (so check the pcb footprint before ordering boards!)
osoyoo-SX1278-ra-02.fzpz (304.3 KB)
mrnams
September 25, 2021, 1:53pm
7
wow, this is what i wanted to have, i shall not use it for PCB foot print, its good to show connections only.
Many thanks
