I’m getting into the nitty gritty of my first project and decided it’s time to use Fritzing. Does anyone have a Jetson Nano FZPZ…any help would be greatly appreciated
You can open this project and take the part from it:
https://fritzing.org/projects/jetson-finder
Part has some errors.
Jetson Nano.fzpz (547.8 KB)
Unfortunately your part doesn’t work.
This part making tutorial may help you correct the part
and has a pointer to where FritzingCheckPart.py can be found. Pcb view is normally suppressed (assuming that you wanted too suppress it!) by coping the breadboard definition in the fzp file to the pcb definition as there needs to be a renderable svg for pcb (but it won’t render a properly formatted breadboard svg in pcb.,) That too is covered in one of the tutorial sections.
FritzingCheckPart.py reports the followining errors
$ FritzingCheckPartw.py part.jetsonnano.fzp
**** Starting to process file part.jetsonnano.fzp
**** Starting to process file svg.breadboard.jetsonnano.svg.bak
**** Starting to process file svg.schematic.jetsonnano.svg.bak
File
‘part.jetsonnano.fzp.bak’
If you wanted a smd part remove the copper0 definition from line 45
Warning 3: File
At line 2
ModuleId ‘JetsonNano’
Doesn’t match filename
‘jetsonnano’
Warning 32: File
‘svg.breadboard.jetsonnano.svg.bak’
At line 22
Scale is not the desirable 1/1000 ratio from width/height to
viewBox width/height.
Warning 32: File
‘svg.schematic.jetsonnano.svg.bak’
At line 13
Error 69: File
At line 96
Error 18: File
svg svg.breadboard.jetsonnano.svg.bak
Error 18: File
Connector connector0pin is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector1terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector2terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector3terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector4terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector5terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector6terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector7terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector8terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector9terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector10terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector11terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector12terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector13terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector14terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector15terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector16terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector17terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector18terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector19terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector20terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector21terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector22terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector23terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector24terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector25terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector26terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector27terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector28terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector29terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector30terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector31terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector32terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector33terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector34terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector35terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector36terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector37terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector38terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector39terminal is in the fzp file but not the svg file. (typo?)
Error 77: File
At line 311
terminalId connector87terminal— can’t be a g as it won’t work.
Error 15: Can not rename
‘svg.pcb.jetsonnano.svg’
to
‘svg.pcb.jetsonnano.svg.bak’
No such file or directory (2)
Error 20: File
During processing svgs from fzp, svg file doesn’t exist
Ok, I’ve created the file from scratch
Jetson Nano-fixed.fzpz (48.4 KB)
If you have downloaded the original part, please delete it and load this new one to prevent confusion
@Ing_Adrian This would be the first and the last time I say this
