Other (please specify)
‘flat sided’ LED from above
Just on breadboard view
A small oblong that covers two adjacent holes of the breadboard so that ‘flat sided’ LEDs can be placed side by side with the option to be able to see red, yellow or green LED’s
Thank you Peter, the ceramic capacitor 200 is about the closest to what I am wanting and will be acceptable for what I am doing. Is it possible to alter its colour to red or green in the Parts editor?
No you would need to modify the breadboard svg. The top view parts should be what you want. In general the top view parts are designed for use on perf board and thus (unlike normal pars in breadboard usually) reflect their actual size (in this case rectangular bar type LEDs on 0.1in centers, I think in various colors that I made some years ago to do exactly what you look to be doing.) Those should do what you want if you can find them. I probably have them somewhere as I keep copies of all the parts I make, but I don’t know where. They were posted to the forum so they will be in the search results somewhere.
Here, make it as a datasheet. LED Flat - Top.fzpz (3.8 KB)
You can change color through Inspector…
But I just checked it doesn’t match to the Flat LED I have.
In Datasheet the short side is 2.54mm, so the LEDs can be placed without any gap on BB.
but, mine is 2.7mm, little wide at the bottom…
