I am having trouble creating a new part.
I need to make a version of the ESP32C3-DevkitC-02.
I made the SVG file and tried to import it, but it always imports blurry.
When I open the SVG on anything that isn’t fritzing it is clear.
Can anyone help me get to the bottom of this? I have attached the SVG and an image of the imported file.
Thanks
vanepp
March 14, 2023, 1:57am
#3
Your input svg appears to be poor quality. This is the breadboard from this part
This should do what you want. Note there isn’t much information that I can find on this board (it looks to be brand new) so this was made by adapting and earlier version to match the jpg image on the web page. The pin spacing should be fine as it is standard but the board outlines may be a little bit off.
Edit: It is possible (probable?) that this board is .1in too wide. That was true of the S2 board below, but the C3 board is no longer available to see if it is the same. If someone has a board…
compared to your part (both displayed in Inkscape)
Note that your connectors are not on 0.1in boundaries (i.e. aren’t on the grid) as well, so this won’t show well in Fritzing.
I expect you would be better off to start from the breadboard in the part above and go from there. As well this tutorial may help somewhat
Someone in this forum post
requested help to fix up a part. So while doing that I decided to record what I needed to do in order to fix the part to provide a tutorial to create new / fix broken parts. If you start from the Tarjeta S4A EDU.fzpz file posted in the above thread, you should be able to recreate my improved part posted in the same thread. I started by loading the original part in to Fritzing, that indicates breadboard is (at first look anyway) pretty good, but schematic and pcb are…
