A google search for “fritzing part esp32-wroom” turns up several hits and a forum search for “esp” turns up several. For the Wroom likely this one (although I didn’t check the number of pins or layout):
The WROVER appears to come in a variety of sizes, so you would need to specify which exact one you want since we would need to modify the part above to match very likely (if the form factor is different.)
This should do what you want. Note the thermal vias are not in pcb as Fritzing can’t produce holes in an SMD part (no copper0) so you will need to drag vias in to the sketch to add them:
the red circles are vias (presumably to a copper pad on the other side of the board although that isn’t said, only implied) and would need to be added to the sketch like this:
