PART REQUEST - ESP32-S3-WROOM-1 Module
Previous work, similar parts
This one from Vanep might be handy, the pinout looks to be different.
Github with good images and pinout guides
There is also a version with no PCB antenna, it has an antenna connector instead.
The official documentation of the part manufacture is linked here use pages 11 and 12.
The WROOM 2 version is almost identical, pins 35,36, and 37 are used for Octal PSRAM and should not be connected to anything.
N/A
This part should do what you want. Note the vias are only in silkscreen (as it is too much trouble to include them in a SMD part) so you need to follow the procedure in
referenced above to add the necessary vias in your sketch…
I needed to set the grid size to 0.01in to align the pins (the bottom pins are on an odd offset)
ESP32-S3-WROOM-1.fzpz (10.2 KB)
Im looking for ESP32CAM-S3-WROOM-1
Thankyou Peter!
I’ll dig into those posts about the vias.
Then you would need to provide a web site with physical dimensions and pin out information for the exact board you want. Pictures are basically useless.
maybe it’s a website with physical dimensions and pin information
ESP32-S3 CAM development board WiFi Bluetooth module onboard ESP32-S3-1 N16R8 module dual TYPE-C interface
ESP32-S3-1-N16R8-module.fzpz (18.9 KB)
This is perfect! Thank you.
This one is pretty spot on, only small issue is there are two Pin 40’s listed.
The one between 47 and 45 should be ‘48’
Fixed version *I think
ESP32-S3-WROOM-1-N16R8-dev-board_1_Fixed.fzpz (27.7 KB)
You can use the USB Type C version with camera included here:
DIYables-ESP32-S3-N16R8-CAM-module.fzpz (17.3 KB)
You can also download from this ESP32 S3 CAM product page
It looks like this images:
ESP32 S3 PIR Motion Sensor Telegram Wiring Diagram
