Arduino 4 Relays Shield
I am always positive this already exists, I just can’t find it.
Name of the part 4 Relays Shield
https://docs.arduino.cc/hardware/4-relays-shield/#tech-specs
Arduino Uno Shield
Other (please specifiy) Arduino Shield
Good morning,
I couldn’t find it either, but I’ll keep looking.
Best regards, Harald!
this is the best I have found so far. It’s embedded in this page and it says made in fritzing.
Do you mean the one in this repo? GitHub - KAST-Tech/fritzing-parts: This repository is all about the fritzing parts that are useful to draw the schematic diagrams of projects. · GitHub
not quite. The one in that repo looks like this.
Hmmm. I found a couple more ‘like’ this one on github. here: SeeedStudio Relay shield V2.x it’s closer to yours, but not quite. EDIT: SeeedStudio Relay Shield v3.0 was the one I wanted to link.
EDIT: hmmm, nope also not close enough.
I found a pretty usable breadboard file directly from Arduino. Maybe a new part can be built from the file and the SeeedStudio examples.
I would just need to revise it — for example, they use styles in it and don’t really stick to the Fritzing guidelines.
Best, Harald!
Is that for this one? Arduino 4 Relays Shield – Control Multiple Devices Easily — Arduino Official Store looks like seeed just directly copied that one.
Yes, here is the source of the file:
Regards, Harald.
Ah, sadly the cad files they have there are kicad.
…but I was able to import them into KiCad very easily.
4RelaysShieldV2.0.zip (277.3 KB)
I think you can actually get it done quite well with the svg from Arduino. I would just need to rename the connectors and define the internal connections. As a basis, I would use the shield from SeedStudio. The footprint is the same after all.
