Mid-Mount SMD Part Creation
I was curious, as follows:
Wondered what Fritzing would do with homemade SVG containing only drawn elements, No Layers.
I hand-coded some svg elements, did not Paragraph them nor made any attempt to ‘pretty it up’ or do anything beyond drawing the elements.
I loaded it in Fritzing for a PCB image and it loaded just fine. All elements correct, including Radius’d corners. The exported Gerber uses the last drawn element for the contour (as I did not Path, Differenced, Subtracted anything). Thus, it did what I expected it to do (if it indeed would load).
FYI - You’ll wonder why the big black triangle? That was an element made as a Path. It only shows in the PCB view but not in exported Gerber. I deleted it in the attached file…
myTest_1_svg.svg.fzp (1.3 KB)
