Adafruit V1 motor shield
DK_Motorshield_V1_Top_B-1-600-450-80
On the assumption you are looking for a part for this, as close as you are likely to come is the Adafruit Motor, Stepper & Servo Shield.fzpz part in the adafruit library on github (it is not loaded in Fritizng by default you need to load it). While it isn’t identical, it is close. This board is discontinued and thus likely not worth the effort required to create a part specifically for it (at least for me).
The complicated boards take quite a bit of time, but if you want to do it there are videos.
