WL-134 134.2 kHz RFID Module
This module is for reading animal RFID tags used in beef and dairy cattle, sheep, goats, dogs, etc. It is commonly used with grazing animals on farms and with pet doors and feeders.
The image is a scaled SVG. Can I get assistance to push this along as a Fritzing part?
WL-134
Picture of module shown below:
Click for Google Search.
OK here is a part and how it was made. Most of the stuff is in this tutorial on making parts.
Started with your svg above. Grabbed a jpeg of the board from this site
https://www.ebay.ca/itm/153965483456
which is slightly rotated and warped. Imported the jpeg in to Inkscape and rotated it and then used the Raster perspective extension to convert it to a flat image like this (original in red converted in green)
then scaled the result to match your svg image
which gives me the placement of components on the board. Then pasted the various components in to the svg overlaying the components on the image.
at the end of that breadboard looks like this (with the image at the back)
then I deleted the jpeg image, ungrouped the svg reset its viewbox and grouped the result and named it breadboard to set the layerId.
The connectors are grouped at the bottom of the svg (which allows me to automatically renumber them with a script which I did here.)
Breadboard is now complete so save it as plain svg and proceed to schematic. For schematic I used Randy’s Inkscape extension for creating Fritzing schematics. First set the sizes and part label
Then set the number of pins on each side
then add the pin names (one side at a time)
which results in a schematic svg like this
Now on to pcb. Copy the breadboard svg to the pcb svg and edit the pcb svg. Ungroup it and remove all the components except for the connectors and the outline rectangle like this
Then turn the outline rectangle in to a 10 thou wide outline for the silkscreen and the connectors in to appropriate form for pcb. Then group the rectangle in to silkscreen and the connectors in to the copper1 and copper0 groups and pcb is done.
Now generate a .fzp file for the part and set the pin descriptions then run the result through FritzingCheckPart.py to clean it up and check it and then produce this .fzpz file by zipping the fzp and 3 svg files. That results in this part which should do what you want.
wl-134.fzpz (14.6 KB)
That’s fantastic, I didn’t really think it was possible!
Unfortunately there is a lot of confusion about the module names, each very different. This is WL-134. Looking at the file names, eg svg.breadboard.wl-134_1_breadboard.svg I wonder if this might cause confusion.
Is this worth changing filenames now before it spreads too much into the wild?
WL Modules
The forum limits the number of links so here is a list of item numbers:
WL-134 32442043927
WL-134A 1005005544805199
W134B 4000426306131
WL-134.2K 1005005401646894
1005001808936046
CZS134 33059902972
FDX-B 1005007951991291
The url that appears in the part name “www.ebay.ca/itm/153965483456” points to the part this was made from (it appears in the Inspector window when you click on the part in the parts bin.) That along with the breadboard image should tell folks if this is the one they want. I don’t think more than that is needed. We may not see any one else ever looking for this (or any of the variants) and I would be inclined to leave it as is until there is a problem. If someone needs one of the other parts it is easy enough to make a new part.
Hi Peter,
Actually for standardisation should we put the name and description like this
<connector id="connector0" name="GND" type="male">
   <description>pin 1</description>
or like this
<connector id="connector0" name="pin1" type="male">
   <description>GND</description>
Like this. The reason being under rare conditions the name field is used to separate parts and thus needs to be unique. The description field does not need to be unique and is thus a better choice for names that may be duplicate.
