Depends on what parts you want. The core parts are generally in a directory called fritzing-parts in the same directory as the Fritzing executable (although the Fedora folks may have moved that.) The easiest way to get parts is likely to start Fritzing and right click on the part in a parts bin or in a sketch then select edit part (new parts editor) from there
then save it as a new part which writes it to the mine parts bin
from there export it to a .fzpz file like this
which writes the .fzpz file to the file system. Now if you unzip the .fzpz file you will get the .fzp file and the 4 svg files that make up the part.
Yes although it needs some post processing to make Fritzing happy. The following tutorial on parts making may help.
Part creation howto part 1 breadboard and pcb
