Type C fast charging circuit for 2s lithium battery with balance and battery protection.
Type C input power source – maximum 5v
Output: - 2S – 8.4v maximum current 1.2A balanced wire welding.
Weight: 2g
Not enough information to do anything with (which is why the template is in this category), pictures are basically useless. A web site with the physical dimensions and the connection information is required to make a part.
That said a google search for “fritzing part Type C fast charging circuit for 2s lithium battery with balance and battery protection” turns up this post which will probably do you (it lacks the USB connector, but that isn’t used in Fritzing anyway.)
