Hi!
anyone has a part like this?
This one from core parts is the closest I see. If you want one with all the pins on the bottom like your picture it is easy enough to (for me anyway) to modify the core part to do that.
edit Since it is pretty trivial to make a new part, I did so
Trimmer-Potentiometer-middle-pin-bottom.fzpz (6.2 KB)
the part to check is the pcb footprint. I left it identical to the current part which may or may not be correct. The pin holes in pcb are currently 0.043in you need to check the data sheet (or a physical pot) to make sure that is big enough and print out the pcb footprint at 1:1 scale and check it against a real part to make sure the footprint is correct.
ooooh a lot of thanks!
The pins are correct but is the same top view and space in board
Are you looking for a top view version of this? Top view is suitable for perf board use, where the size of the part is identical to the physical size of the part rather than an angle picture of the part that is the standard in breadboard view. Top view parts tend to look like this:
which is from this forum post:
but there isn’t a top view trim pot version yet that I can find. It is easy enough to make one if that is what you need though.
Here, I updated this with new PCB pattern as per as the footprint I found…
Trimmer-RM063.fzpz (6.5 KB) (updated silkscreen)
Hope, this will help…
thanks again!!
But I need it for perfboard / veroboard
Okay,
for top-view part, having the part would be very helpful…
But, in simple & help of datasheet, I can only provide you this…
Top - Trimmer-RM063.fzpz (4.1 KB)
oooooh it’s perfect now!!!
Thanks a lot for your work
