FritzingCheckPart.py is complaining that the dimensions are in px (and thus the sizes will potentially be incorrect!):
$ FritzingCheckPartw.py part.mt3608_M_no.fzp
**** Starting to process file part.mt3608_M_no.fzp
**** Starting to process file svg.breadboard.mt3608_M_no.svg.bak
**** Starting to process file svg.schematic.mt3608_M_no.svg.bak
**** Starting to process file svg.pcb.mt3608_M_no.svg.bak
File
‘part.mt3608_M_no.fzp.bak’
If you wanted a smd part remove the copper0 definition from line 47
Warning 4: File
At line 2
No referenceFile found in fzp file
Warning 11: File
At line 57
Type female is not male (it usually should be)
Warning 19: File
‘svg.breadboard.mt3608_M_no.svg.bak’
At line 6
Height 48.826px is defined in px
in or mm is a better option (px can cause scaling problems!)
Warning 19: File
At line 6
Width 104.882px is defined in px
Warning 19: File
‘svg.schematic.mt3608_M_no.svg.bak’
At line 6
Height 28.65px is defined in px
Warning 19: File
At line 6
Width 51.1px is defined in px
Warning 24: File
At line 53
Font family ‘DroidSansMono’ is not Droid Sans or OCRA
This won’t render in Fritzing
Warning 19: File
‘svg.pcb.mt3608_M_no.svg.bak’
At line 6
Height 48.939px is defined in px
Warning 19: File
At line 6
Width 105.633px is defined in px
although at least schematic appears to be scaled correctly (breadboard and pcb are harder to determine and may or may not be correct.)
If you can find the time (always in short supply unless you are retired like me
) uploading them would be appreciated. A google search for this part didn’t find anything else thus the reference to the mini360 part which isn’t a perfect match like yours …
