Searching for 3.5mm 4pin Jack YD-PJ-3566
I’m new to fritzing and play a bit around… Now I need help…
I search for the part file of a 3.5mm jack. This Model:
Regards
This rather odd part should do what you want. Fritzing doesn’t do slots, so the pins are implemented by a copper pad and two .8mm holes spaced to give the required 1.5mm length. You may need to file or use an exacto knife to widen the slots a bit to fit the pins. I’m told the board houses will produce these (I have not tried.) DRC (design rules check) will break and is not fixable, the copper layers are overlapping but they need to be to get plating through for the connectors. As always before ordering boards from this print the pcb layout out at 1:1 scale and check it against a real part.
YD-PJ-3566.fzpz (4.9 KB)
